Go to Post Having someone with as much mainstream appeal as will.i.am is a great strategy to draw large amounts of attention to a program that has been relatively hidden to the masses. - Karthik [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Authentic Touch Landscape
ADVERTISEMENT
Unread 01-23-2007, 06:51 PM
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Rookie Year: 2007
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Gear Tooth Sensor
Hey guys, I have a rather wierd problem.
I'm trying to use a gear tooth sensor with easy c. When I use the default gear tooth sensor functions I don't get any readings from our sensor. But when I use the GetDigitalInput function, I get a reading from the sensor? Why would this be?
Thanks,
Nathan
Unread 01-23-2007, 07:08 PM
sjung9442 sjung9442 is offline
Student Mentor
FRC #0122 (NASA Knights)
sjung9442 is an unknown quantity at this point
Re: Gear Tooth Sensor
I don't know much about easy C program, but I know that easy C does not give exact code we need. So, try look at Kevin Watsons encoder code and find how gear tooth sensor works. Than, try to combine or copy Kevin Watson's code to easy C.
If you are getting digital input, that is great. Because gear tooth sensor gives digital input. All you have to do is convert the data to analog and find the right parameter.
Unread 01-23-2007, 07:11 PM
michniewski michniewski is offline
FRC #1353
michniewski is an unknown quantity at this point
I'm not familiar with easyC (being a user of mplab), but maybe the gear tooth sensor functions rely on some particular digital input and you have it connected to a different one. Also, check for any configuration information, or perhaps calibration.. just a guess.
Good luck!
- Michael Michniewski
Team 1353, The Spartans
Greater Toronto Regional
- look for the Spartan mascot
Unread 01-23-2007, 07:37 PM
Nathan's Avatar
Rookie Year: 2007
Yeah, the gear tooth sensor needs to be hooked up to Digital ports 1-6 to work, so says the easy c manual...
Also I have a variable keeping track of how many times the Digital port == 1, which is what I think the gear tooth sensor function does.
I just can't figure out why the default function won't work...
-Nathan
Unread 01-12-2008, 02:09 PM
Team 562 Team 562 is offline
FRC #0562
Team 562 is an unknown quantity at this point
Nathan,
Sorry for the late reply. Maybe you have already figured it out since your post but I have set up the gear tooth sensor successfully with the easyC default code. The sensor returns an absolute value based on the number of times it senses a gear tooth passing by. So, all you need to do is create a variable of type "int", assign it the value from the GetGTSensor() function, and display the value of the variable with a screen print.
Good Luck.
Gear Tooth Sensor Zoom Programming 46 01-22-2008 07:05 AM
Gear Tooth Sensor nukem Programming 9 02-04-2006 07:21 PM
Gear Tooth Sensor Trouble cprogrammer Programming 1 01-24-2006 12:48 PM
Gear Tooth Sensor Talha Electrical 1 01-23-2006 08:29 PM
Gear Tooth Sensor AMIRAM Electrical 2 01-22-2006 03:09 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
