Ramp alternatives?
I've heard and seen alot of discussion about ramps. This is an obvious solution for the endgame, but I was just wondering if anyone out there is using a lift system instead of ramps? Or any other method?
Re: Ramp alternatives?
http://www.chiefdelphi.com/forums/sh...ht=Lift+system
There have been many discussions about Lifts v. Ramps |
Hoverbots, of course!!
(Sorry I just had to) |
but whats going to power it after the match is over?
A lift could be kept up after ower is turned off if it is a pneumatic piston on a dual action solenoid. These solenoids have three positions: extend (fwd = 1, rev = 0), middle(fwd = 0, rev = 0), which doesn't change the current state, and reverse(fwd = 0, rev = 1). Turning off the bot should only put the fwd and rev to zero, leaving an extended lift extended and judgable.
In the past, robots have never been powered back on to get them off the field. Take it to the pit and restore it to it's original configuration. |
| CMUcam2 alternatives? | groves | Technical Discussion | 6 | 01-10-2007 09:09 AM |
| 3ds max alternatives? | Mazin | 3D Animation and Competition | 24 | 11-11-2006 06:43 PM |
| Gear alternatives | Booger | Technical Discussion | 6 | 07-23-2006 01:27 AM |
| USB-to-Serial Interface Alternatives | Josh Adelson | FIRST Tech Challenge | 8 | 03-22-2006 08:40 AM |
| VEX Alternatives... | 114gopher | FIRST Tech Challenge | 3 | 04-24-2005 07:02 PM |
