Go to Post The most important deisgn criteria is always performance in any of the parts / systems we design. But we do try to abide by the saying -- if it doesn't look good (right), it probably isn't good (right). - Adam Freeman [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
ITT Tech
ADVERTISEMENT
Unread 01-26-2007, 04:55 PM
Rinaldi 427's Avatar
Rinaldi 427 Rinaldi 427 is offline
any help but programming
AKA: Angelo Rinaldi
FRC #1482 (the ghosts)
Rinaldi 427 is an unknown quantity at this point
1482 Help with Compressor
We need to know if using 2 compressors simultaneously is allowed during the competition. Thanks
team 1482 proudly Canadian. proudly student built
Unread 01-26-2007, 04:58 PM
EricH's Avatar
EricH EricH is offline
...has read the 2012 Manual
FRC #0330 (Beach'Bots)
Send a message via Skype™ to EricH
Re: 1482 Help with Compressor
I don't think so. However, as far as I know, there is no rule specifically allowing or disallowing it. (Somebody will probably prove me wrong shortly, but I don't really mind.) I'd ask Q&A.
What would you want 10 pounds of compressor for, anyway? (Yes, that's about 5 pounds/compressor.)
Paths a rules question takes:
Official: Post to Q&A-->GDC reviews-->Official answer posted on Q&A.
Unofficial: Post to CD-->CD views and comments, sometimes using The Manual and interpreting it-->Somebody goes the Official route -->Answer gets posted on CD eventually, as a quote from Q&A.
Which one takes longer for an official ruling? Therefore, which one makes more sense to use?
Unread 01-26-2007, 05:58 PM
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Did you get 2 compressors in your kit? I should think not. A compressor is considered another motor and another non-legal item. Simply put it would not be legal.
I do have to wonder though, why would you want another compressor on board?
-Mike
Unread 01-26-2007, 06:09 PM
sanddrag sanddrag is offline
back to school ;-)
FRC #0696 (Circuit Breakers)
Team Role: Teacher
to make a faster lift of course.
Support Team 696 on DonorsChoose!
Unread 01-26-2007, 06:30 PM
AKA: Angelo Rinaldi
its to help our lift since today we got an e-mail saying that we cant use the cylinders we ordered from bimba and now its making life difficult for us and we might have to use a 2'' bore which uses more air than we have
Unread 01-28-2007, 05:25 PM
Brian C's Avatar
Brian C Brian C is offline
Chief Cook and Bottle Washer
no team (J-Birds, CIBorgs)
Rookie Year: 1999
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
I believe you're allowed to use up to 4 of the clippard tanks this year. Have the compressor feed into these tanks at 120psi and then use the fixed regulator to lower the operating pressure of your pneumatics to 60 psi or less. The stored air in the tanks should provide enouogh volume to drive what you need.
Check the pheumatics manual for help in setting up the system.
Cut to size, Beat to fit, Paint to match!
Mentor for teams 1468 & 4006
Unread 01-30-2007, 10:49 PM
AKA: Angelo Rinaldi
thanks but i dont need help with any of that i have done the math and we would need 78% more air to go 12'' and we are already useing four tanks at 125 psi we have contacted first and we are not alowed to use two comprresors
Unread 01-31-2007, 06:46 AM
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #0167 (Children of the Corn)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Does lowering the pressure to, say, 30 psi rather than 60 then make you have enough air, or would 30 psi not give you enough power?
Also, depending on how close you are, you may just have to start your lift with 15/20 seconds left in the match so it has time to get filled all the way by the end.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - Present
part shipment help 1482 ! Rinaldi 427 General Forum 0 01-25-2007 01:22 AM
somebody help me with my compressor please royboards05 Pneumatics 4 02-18-2005 11:38 PM
Help With Compressor Code fred Programming 6 01-21-2005 04:40 PM
Problem with compressor Nick R. Pneumatics 3 02-21-2003 09:51 AM
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 06-24-2002 01:11 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
