I'm trying to write a function that reads values from eeprom and stores their values into variables passed into the function. This is what it looks like:![]() Code:
void Terminal_eepromreadset(unsigned char set, unsigned char *data1, unsigned char *data2, unsigned char *data3, unsigned char *data4)
//Consolidate this on verify that it works!!!
unsigned int address = set * 4 -1;
//*data1 = EEPROM_Read(address + 1);
//*data2 = EEPROM_Read(address + 2);
//*data3 = EEPROM_Read(address + 3);
//*data4 = EEPROM_Read(address + 4);
// later on in another function this is how it's called:
unsigned char version1;
unsigned char version2;
unsigned char version3
unsigned char version4;
Terminal_eepromreadset(0, version1, version2, version3, version4); break;
For some reason I get the following warnings when I compile: Code:
C:\frc\FrcCode_2007_8722\terminal.c:550:Warning [2054] suspicious pointer conversion C:\frc\FrcCode_2007_8722\terminal.c:550:Warning [2054] suspicious pointer conversion C:\frc\FrcCode_2007_8722\terminal.c:550:Warning [2054] suspicious pointer conversion C:\frc\FrcCode_2007_8722\terminal.c:550:Warning [2054] suspicious pointer conversion Any ideas? |
Re: Pointers/References?
Code:
void Terminal_eepromreadset(unsigned char set, unsigned char data[4])
unsigned int address = set * 4;
data[0] = EEPROM_Read(address);
data[1] = EEPROM_Read(address + 1);
data[2] = EEPROM_Read(address + 2);
data[3] = EEPROM_Read(address + 3);
Code:
void Terminal_eepromreadset(unsigned char set, unsigned char *data) Quote:
Code:
Terminal_eepromreadset(0, &version1,.....) Code:
unsigned char version[4]; Terminal_eepromreadset(0, version); Confusing as dirt? ![]() ttyl, --buddy |
Is there a way to make the multi-variable-in-the-input idea work? It cleans the code up so much that I would rather keep it that way. Can someone at least tell me why I get that message about a "suspicious pointer conversion"? I'm sure the code would work if I could pass more than just one variable into the function (which is what it seems). |
I think I (might) have fixed it. (at least, it's not giving me errors anymore...)The following is the example in entirety: Code:
// Eepromhelper.c
#include "eeprom.h"
//Version verify codes:
unsigned char version1 = 0;
unsigned char version2 = 1;
unsigned char version3 = 1;
unsigned char version4 = 0;
//end verify codes...
// Verify codes are supposed to be for version check so in case the wrong version data is stored the robot will not use it (until saveing, which the robot will post a warning of overwrite (still in the works...))
// EEprom section:
void Terminal_eepromwriteset(char data1, char data2, char data3, char data4, unsigned char set)
EEPROM_Write(address + 1, data1);
EEPROM_Write(address + 2, data2);
EEPROM_Write(address + 3, data3);
EEPROM_Write(address + 4, data4);
void Limit_S0witch_Max(unsigned char switch_state, unsigned char *input_value, unsigned char *yep){}
char Terminal_loadFromEeprom(char set)
char rtn = 0;
//This routine loads four char values from eeprom using a set switch te determine which bits to load.
//Set starts with zero and also indicates what address to use (starting with zero)
//Returns 0 if send to buffer success, 1 if read failed, 999 if set number is invalid
//Make sure this information is mirrored in Terminal_saveToEeprom() !!!
switch (set)
case 0: //this is an example set, meant only for verification of data...
//This is also viable for version verify, for automatic reset...
Terminal_eepromreadset(0, &version1, &version2, &version3, &version4); break;
default: return 999; break;
return rtn;
char Terminal_saveToEeprom(char set)
//This routine saves four char values to eeprom using a set switch te determine which bites to save.
//Returns 0 if send to buffer success, 1 if buffer is full, 999 if set number is invalid
//Make sure this information is mirrored in Terminal_loadFromEeprom() !!!
if (EEPROM_Queue_Free_Space() > 4)
switch (set)
Terminal_eepromwriteset(version1, version2, version3, version4, 0); break;
else
return 1;
return 0;
// End eeprom section...
![]() Hope this can be helpful to some others |
[quote=htwiz2002;567274] Code:
![]() Quote:
Also, why are you using global variables here instead of declaring them inside this function? Also, perhaps you should name your case.... Code:
#define VERSION_SET (0) .... ... case VERSION_SET: .... Code:
default:
return 999;
break;
A programmer's job is to write documentation that happens to compile.... ![]() Suggestions: Use whitespace, it's free. Avoid global variables like the plague. If you must use globals, stick a 'g' in front of the name, again so that you know it's a global. Make all your globals 'static'. This means that they won't conflict with another global in a different file. That can cause huge headaches. ttyl, --buddy |
[quote=buddy.smith;567537]I was just suggesting the array method to show the possibility. You can do it the way you were doing it before.... (details below)
What's the -1 for? Why not just set*4, then add 0, 1, 2, 3? Quote:
![]() Anyways, I'll make some major changes.... With the "break" thing I was trying to consolidate things so that I wouldn't need to scroll half a mile just to get from section to section, while (hopefully) improving readability (since most of the code that I combine to one line doesn't need (normally) to be changed or read much. Also, my globals (generally) have the file's name prefixed so as to help prevent them being used (normally, again) outside of the file. Problems do arise when I try to access them o-o-f, but since I moved the handler code i haven't needed to (much). Again, code in beta, far from finished. I was using the version globals for version checking and for the test set. They will become #define s soon enough, as well as many of the other global variables. |
No worries.
I personally use vim with some nice things for auto-indenting code. Also, if your functions are so long that they won't fit on one screen, it's a good sign that your function might be too long. But I've digressed far beyond the initial topic. If you require more assisstance, I'll be trolling this forum. I'd love to help any other teams that need it.... ![]() Another thing you can do, is group the things that will be in your eeprom into a struct: Code:
struct {
unsigned char foo;
unsigned char bar;
} gEepromStruct;
[code] void eeprom_read(void *pData, unsigned char size) { /* Read data into pData here */ } void test( void ) { eeprom_read( &gEepromStruct, sizeof(gEepromStruct)); } Now your eeprom read/write are generic, and you can put anything you want in the eeprom without changing that code. ttyl, --buddy |
Also, you can prevent global variables from being accessed outside of their file by declaring them as static. For example:
In user_routines_fast.c: Code:
static int auto_counter;
void User_Autonomous_Code(void)
Code:
extern int auto_counter; /* This will not compile! */ |
| pic: Robonauts' Magnum Shoots 3 Pointers with WNBA Comets | Natchez | Extra Discussion | 8 | 10-28-2006 07:26 PM |
| Pointers in EasyC | P1h3r1e3d13 | easyC for FRC | 6 | 03-12-2006 11:02 PM |
| Can't use pointers nor refrences. | cibressus53 | Programming | 9 | 11-05-2004 02:44 PM |
| Pointers to structs? | Jeff McCune | Programming | 2 | 02-17-2004 12:17 PM |
| Laser Pointers.. | archiver | 2001 | 18 | 06-23-2002 11:08 PM |
