Go to Post ...if two good things are good by themselves let's do them both together to make a better thing. So who's up for an apple pie burrito? - Katy [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
The Chrysler Foundation
ADVERTISEMENT
Unread 01-31-2007, 12:43 AM
PuffGoLe PuffGoLe is offline
PuffGoLe is an unknown quantity at this point
Programming with Two CMU Cams
With one camera connected to the serial port, and one to the programming port, how should our team go about programming so each can track a light? Thanks in advance.
Unread 01-31-2007, 05:26 PM
kitscuzz's Avatar
kitscuzz kitscuzz is offline
Not alotta posts
AKA: Kit
FRC #1389 (Worst Case Scenario)
kitscuzz will become famous soon enough
Re: Programming with Two CMU Cams
You'll probably want to just take the camera.c and tracking.c (and their related .h files) and make a copy. Then change all of the static and extern variables to slightly different names. Then just call the camera handler and the servo track in User routines. http://kit.kitkorp.com/frc_camera_doublecamera.zip Shows the laziest of the lazy version of this code. There are some changes marked with "Brian" in the tracking2.h, tracking2.c, and tracking.h to limit the scope of each camera to half on either side, and reverses so they each start in the middle and spread out.
Unread 02-01-2007, 02:56 PM
Metalgod4eva Metalgod4eva is offline
None #0870
Metalgod4eva is an unknown quantity at this point
Its never a great idea to name some slightly different for better read ability use _. Like if I had a function that writes I should name it write_function. Same with headers and source files. Unless its local variables dont just add a 1 or a random X. It will save you the headache in the long run.
Unread 02-01-2007, 06:02 PM
iwdu15 iwdu15 is offline
FRC #0811
iwdu15 is an unknown quantity at this point
question for you....you said youv connected 2 cameras to your RC, both to the 232 ports.....how did you go about connecting the cameras that way and how did you transmit info during runtime? thanks
--iwdu15
--team811
Unread 02-01-2007, 08:45 PM
kitscuzz's Avatar
Not alotta posts
AKA: Kit
You set up one camera normally through the TTL port with the TTL to 232 adapter. The second goes through a modified serial cable that connects the programming port to your camera.
The easiest way to simply test everything is to buy a ***null modem cable*** connector for your serial cable and simply plug the camera serial directly into the programming port.
To test whether or not it's working all you need to do is download the default camera code and change the line in camera.h from
// #define CAMERA_SERIAL_PORT_1
#define CAMERA_SERIAL_PORT_2
to
// #define CAMERA_SERIAL_PORT_2
IMPORTANT NOTES:
You won't have any terminal with two cameras. You must make sure that if you use both that you set
stdout_serial_port = NUL; in user_routines User_Initialization.
Some extra notes:
If you decide to modify the cable to go to a PWM output (which is what you'll do if you decide to go into competition with it) You'll need to ruin a serial (or make your own) and make the following connections:
1 0 2 3 0 << This is the serial port on your Robot controller
0 0 0 0
connect pin one to the black on a PWM, pin 2 to the red, and 3 to the white/yellow.
Unread 02-01-2007, 08:47 PM
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
The easiest way to simply test everything is to buy a male-to-male connector for your serial cable and simply plug the camera serial directly into the programming port.
You would need a null modem cable, not just any male-to-male cable.
Here is some more info about null modem cables, including wiring diagrams in case you wanted to make one yourself by splicing two cables.
Unread 02-01-2007, 08:57 PM
kitscuzz's Avatar
Not alotta posts
AKA: Kit
Sorry, fixed.
Oh, and for those of you who are using, the code http://kit.kitkorp.com/frc_camera_doublecamera.zip I've now made it so that it works like originally planned. The Cameras both pan from left to right in a full arc. All of the edited code was removed save for the dual camera functionality.
CMU 2 cam with Vex Nathan Technical Discussion 13 11-11-2006 07:55 PM
cmu cam programming ideas lineskier Programming 1 01-09-2006 11:41 AM
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 11-01-2005 06:03 PM
CMU / RC / programming error N7UJJ Programming 3 02-18-2005 04:05 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
