Go to Post Yup, looks like FIRST is infiltrating the American sports culture. And that's the long and the short of it. - Taylor [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
Team 221 LLC
ADVERTISEMENT
Unread 01-31-2007, 11:58 AM
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
Team Role: Leadership
Rookie Year: 2007
seanl will become famous soon enoughseanl will become famous soon enough
autonomous mode
hi im the programmer for team 867, i was wondering is there any default code for autonomous. and i have another question, how can we activate autonomous mode for testing.
Unread 01-31-2007, 12:01 PM
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
FRC #0111 (WildStang)
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: autonomous mode
This thread may help you out
http://www.chiefdelphi.com/forums/sh...threadid=53137
Unread 01-31-2007, 12:14 PM
seanl's Avatar
Rookie Year: 2007
Re: autonomous mode
ok kool i got it. this has nothing to do with this but i want to add a dead zone on the joystick. so like the robot wont move the split second you touch the joystick, how can i do this.
Unread 01-31-2007, 12:38 PM
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: autonomous mode
I want to add a dead zone on the joystick. so like the robot wont move the split second you touch the joystick
There is already a dead zone built into the Victor speed controllers. But whether you realize that or not, the joysticks must not be giving the response you want.
You could try something simple like this, to basically ignore the values near the centre of travel:
Code:
if ((joy >= 120) && (joy <= 140))  joy = 127;
Or a more sophisticated "exponential" method:
Code:
speed = joy - 127;
newspeed = ((speed * speed) / 127) * sign(speed);
I have attached a Labview 8 application that demonstrates various joystick response curves.
Good luck,
Mike
Unread 01-31-2007, 12:56 PM
seanl's Avatar
Rookie Year: 2007
Re: autonomous mode
i have 2 questions
1. where do i splice in the code you gave me i was looking through the code i cant see where to put it.
2. do i connect the user interface to my computer for running the labview program.
Unread 01-31-2007, 01:41 PM
Re: autonomous mode
Code:
This is a good idea, but I would propose the following enhancement to make it a little more flexible
Code:
#define JOYSTICK_DEADZONE   5
if((joy >= (127 - JOYSTICK_DEADZONE)) && (joy <= (127 + JOYSTICK_DEADZONE)))
  joy = 127;
Then, to extend that even further, you could create a macro so that you could apply deadzones whenever you needed to.
Code:
#define DEADZONE(input, dz) (if(((input) >= (127 - (dz))) && ((input) <= (127 + (dz)))) (input) = 127;)
DEADZONE(joy1, JOYSTICK_DEADZONE)
DEADZONE(joy2, JOYSTICK_DEADZONE)
Notice that the lines that "call" the macto don't have semicolons. This is because there is a terminating semicolon at the end of the macro itself.
Well, if you think about this logically, your outputs (pwm/relay/analog/digital outs) are based on your inputs, so it makes sense that deadzone code would be placed somewhere after the inputs are read, but before the outputs are written. Depending on how your inputs map to outputs, you may have intermediate calculations. It would then make sense to place your deadzone code before those calculations. When in doubt, take a deep breath and think through the problem. Programming is about thinking logically. Go step by step and you'll figure it out.
I don't know anything about the way that labview works. Hopefully someone else can answer that question.
Unread 01-31-2007, 02:59 PM
mluckham's Avatar
Re: autonomous mode
i have 2 questions
If you are using MPLAB, you will see (in the default code) where the joystick values are read, then the resulting values are assigned to the Victor pwm output variables. So you put the joystick code JUST AFTER the joystick value is read. You will have to make your own decisions for variable names, etc. And the code I provided is only for one joystick axis - you will have two joystick axes, so will need twice the amount of code.
Labview is a graphical development environment that runs on your PC. A copy of Student Labview was included in the KOP this year. I am attaching a screen shot of the Labview program running the Joystick application - you will get the idea that it is only useful to ILLUSTRATE how joystick values might be processed. The simulated joystick input is the horizontal slider at upper left. The three scales below show linear (direct), exponential, and logarithmic conversions.
Autonomous Mode EricWilliams Programming 8 01-10-2007 09:58 AM
Autonomous Mode Yellow Eyes Programming 2 02-18-2004 08:16 PM
autonomous mode Stephanie Programming 2 01-25-2003 06:57 PM
Autonomous Mode David Bryan Programming 1 01-21-2003 08:15 PM
autonomous mode? bigwalt Technical Discussion 1 01-21-2003 12:14 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
