Autonomous mode
Where are the variables that are used in autonomous code declared?
Re: Autonomous mode
Just make sure you declare them outside of the "while(autonomous_mode)" loop and everything should be fine.
need help programing on our controls
i need help on how to program our controls using labview 8.2
Re: need help programing on our controls
i need help programing our controls using labview 8.2
Re: Autonomous mode
You might want to delete your double-post because people will see it and negative-rep you...
You don't straight-up code with LabView. You either use easyC or MPLAB to code the controls. I don't know LabView well enough to instruct you on how to use it, but there are plenty of threads on how to program around here. JBot |
| Autonomous Mode | fallen751 | Programming | 14 | 02-08-2007 11:28 PM |
| Autonomous Mode | Slick | Programming | 22 | 02-01-2007 06:26 PM |
| Autonomous Mode | Yellow Eyes | Programming | 2 | 02-18-2004 08:16 PM |
| Autonomous Mode | tysonwormus | Rumor Mill | 11 | 01-08-2004 09:59 PM |
| autonomous mode | Stephanie | Programming | 2 | 01-25-2003 06:57 PM |
