This is the first year our team has used the encoders and we have discovered you need to disable any inactive encoders. Kevin's readme in the encoder project sais that instructions to disable encoders are in the encoder.h file. After checking the latest code, no instructions were found.
Are the instructions in another file or can someone give help on disabling the encoders. |
Re: Disable Encoders Problem
All you need to do is the following:
1. Open "encoder.h" 2. Find the lines that look like: Code:
#define ENABLE_ENCODER_1 #define ENABLE_ENCODER_2 #define ENABLE_ENCODER_3 #define ENABLE_ENCODER_4 #define ENABLE_ENCODER_5 #define ENABLE_ENCODER_6 Code:
#define ENABLE_ENCODER_1 //#define ENABLE_ENCODER_2 #define ENABLE_ENCODER_3 //#define ENABLE_ENCODER_4 //#define ENABLE_ENCODER_5 //#define ENABLE_ENCODER_6 |
I would still recommend that he comment out the #defines in the header file. Doing so would both disable irrelevant interrupts, and eliminate code that won't be called anyway from the hex file. |
When he said he wanted to disable an inactive encoder, I took it to mean the encoder was to be active for a while, possibly during autonomous, and then be disabled, not that the encoder was totally absent.
good luck, and if I can help, gimme a yell. -Q |
I've never understood the && with the enable bit in the interrupt handler. If the interrupt isn't enabled, there will be no jump to the interrupt vector so that test will never be executed. Without the interrupt enabled, it's just an ordinary input pin.
-Kevin |
There is only one (low-priority) interrupt handler. It will be called when any interrupt occurs, and the handler has to check all the possible sources in order to service the interrupt properly. The program won't know not to deal with a flag for a disabled interrupt unless you also check the associated enable bit. You don't really want a serial port interrupt to end up running the service routine for a "disabled" encoder.
#10
Thanks for all the help.
#11
This is where I part company with MicroChip's implementation. If you don't enable the interrupt, it should never set the interrupt flag for that interrupt, in my opinion, because an interrupt should not have occurred. I guess one more reason I'll probably opt for something other than PICs for my personal projects. |
| Autonomous enable/disable | Culvan Van Li | VEX | 4 | 09-21-2006 12:03 PM |
| Bypass Disable Switch | jakep | IFI Control System | 36 | 08-19-2006 11:46 AM |
| Question about human disable | Collmandoman | Programming | 6 | 03-10-2005 10:30 PM |
