Go to Post Don't worry about where you will be. Just consider youself lucky for being where you have been. - sanddrag [more]
Go Back   Chief Delphi > Technical > intelitek easyC/REC information > WPILib
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Team 221 LLC
ADVERTISEMENT
Unread 02-10-2007, 01:06 PM
billdar billdar is offline
FRC #2085
billdar is an unknown quantity at this point
Variable Scope
I know its pretty late asking these questions, but we haven't gotten
to building a competition port dongle yet and I have a nagging question
on variable scope within the 3 WPI functions (Initialize, Autonomous,
Operator).
The kids have been practicing with code laid out like this:
main()
int someVariable;
while (1)
doSomethingTo(someVariable);
And they have been assuming that someVariable will retain its
value each time it loops.
Two questions on this, if they write the same kind of code in either
the Autonomous() or OperatorControl() functions:
- Will the forever loops break the background competition port monitoring
task?
- How do I define a variable that retains its value when Autonomous()
or OperatorControl() loops?
Thanks,
-Bill
Team 2085
Unread 02-11-2007, 05:26 AM
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud of
Re: Variable Scope
WPILib will automatically break the program out of Autonomous() when the operator control period starts. Even if you have an infinite loop in your autonomous function it will put you into the OperatorControl() function when the autonomous period ends. It will not break you out of the Initialize() function which is where you probably want to be initializing things like cameras, gyros, etc.
The variable scoping is just as you described and follows normal C rules. However those variables declared as locals in the Autonomous(), OperatorControl() or Initialize() functions will not be available to each other or to other functions (unless passed as arguments).
To make variables that are available between functions they need to be global in scope - declared outside of any functions. And you need extern declarations for them somewhere, probably in a header file.
Also, you should not put anything in the main function for a competition program - but an empty main function needs to be there to satisfy a linker requirement.
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 02-11-2007, 10:12 PM
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: Variable Scope
If you are using EasyC then go to the Main() routine and create variables in the Globals block.
camera scope problems xrabohrok Programming 4 01-15-2007 07:48 PM
Camera variable scope question Validius Programming 1 01-28-2006 08:24 AM
Save a variable dawonn Programming 7 04-23-2005 07:30 AM
Interrupt Handlers and Variable Scope kaszeta Programming 2 02-14-2004 05:30 PM
variable? manodrum Programming 11 04-01-2003 04:20 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
