I am wondering if it is legal to wire a relay (dpdt) after the spike in order to control 2 valves with one relay?
Re: help is this legal
I think what you can do is take the two black wires from the solenoid to a ground on the breaker panel, and then put each red one on a M+ and M- on the Spike relay. You should check on this though.
What Sanddrag said is what we do each year and it works just fine and has been accepted by judges in the past, in fact it used to be in the manual.
minion,
Sanddrag is correct, the solenoids will be wired between the negative lead of the battery and each motor output on the Spike. There is a description in the Tips and Guidelines on this I believe. I think the Spike manual on IFI 's website also disucsses this application. |
okay i know that you can do what you decribed but i need to pulse the pneumatic cilinder. So instead of having to spikes i have one with a relay it. The relay controls the first valve and the second is normal just connected the both positives to spike and ground to ground. Every time the spike has any power going through it the relay chages state and switches the first vale to let air though it and when there is no power the first valve doesn't let air though it. so is this legal
No, it's not legal.
thanks
You should be able to do what you want simply by connecting one side of the solenoid to the Spike output and the other side of the solenoid to ground. |
| Is this legal | IndySam | General Forum | 19 | 03-26-2006 07:34 PM |
| Is this legal | Bob92 | General Forum | 36 | 02-24-2005 02:10 PM |
| pic: (447) Is this legal? | rufu5 | Robot Showcase | 12 | 02-15-2005 08:52 PM |
| Would this mesh be legal? | wun | Rules/Strategy | 3 | 02-21-2004 08:28 AM |
| is this legal? | archiver | 2001 | 2 | 06-23-2002 11:58 PM |
