Go to Post Dee and I pooling our brain cells almost make a full deck... - RoboMom [more]
Go Back   Chief Delphi > Technical > intelitek easyC/REC information > easyC for FRC
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Cross the Road Electronics
ADVERTISEMENT
Unread 02-18-2007, 02:18 AM
Asheron Asheron is offline
Asheron is an unknown quantity at this point
Need pnuematics Idea Critique please help!
I'm using EasyC.
I was thinking of controlling the soleniods in the following manner (and this is psuedocode)
Setup info: I have a global button_counter(1) integer that keeps track of how many times a button has been pressed on the joystick, and I have a relay, and I have a button(1) variable that holds input from one of the joystick buttons. The example uses 'button1' and 'button_counter1' but could work for buttons 1 through for 4 to control seperate soleniods or relay attachments.
If button(1) is pressed
button_counter1 ++
// turn on relay in one positive direction
if button_count == 0
{ while (button not pressed again)
set relay1(1,0)
else if button_count == 1
{ set relay1(0,0) }
else if button_count == 2
{ set relay1(0,1) }
else { set relay1(0,0); button_count = 0;}
end if
end if
The purpose being to be able to have the flow controlled for each soleniod by only 1 button being pressed. I don't have access to the robot to know exactly how they work. I'm doing this code from remote location and need help as soon as possible. Will this work, if not why not? Please PM me if you have a suggestion.
Also, how do I capture the event of a button press?
I don't know how to set a listener for an OI digital input that could then be the codition for the original if
Unread 02-18-2007, 11:01 PM
GuitarManiac511's Avatar
GuitarManiac511 GuitarManiac511 is offline
Programmer
AKA: Joshua Miller
FRC #1959 (Aye Robot)
GuitarManiac511 is an unknown quantity at this point
Send a message via AIM to GuitarManiac511 Send a message via MSN to GuitarManiac511 Send a message via Yahoo to GuitarManiac511
Re: Need pnuematics Idea Critique please help!
To capture the press event, you need one global variable and another var that can be local or global (doesn't matter). For my example, I will use the trigger of joystick on port 3. the [] means to use a block. I may not use the correct names for them, but you should get the gist of it...
Global:
int TrigWas;
Local:
int TrigIs;
TrigIs = [IOAnalog(3, 1)];
if (!TrigWas & TrigIs)
// Trigger was pressed...
TrigWas = TrigIs;
As for the rest of the coding, I'm not sure what your trying to do...
Need critique of programming idea and info!!! Asheron Pneumatics 2 02-18-2007 10:21 AM
Need Help w/ pnuematics programming idea!!! Asheron easyC PRO 0 02-18-2007 02:17 AM
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 08:46 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
