Go to Post Let's see some love for these fine people. Let's give it up for the refs. - Andy Baker [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ITT Tech
ADVERTISEMENT
Unread 02-19-2007, 01:44 PM
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Let's see if you can help me... (Motors)
Ok, out robot uses two pivot points in the arm. One is at the top of the supports... the arm goes down and another near the ground that goes back up. Understand?... Kinda like a shoulder/elbow arm.
We have two window motors mounted halfway up the supports that have a smaller sprocket that run up to the arm with a bigger sprocket. I think its a 4 to 1 ratio.
The arm raises fine and stays up fine with no problems. The problem comes in when we want to drop the arm down. Right when you start dropping the arm it will not stop. It just keeps dropping all the way until it hits the floor. Then we have to raise it up and repeat the process when we want to go down again. This gives us very little control.
Any help on how we can fix this problem?
-Thanks,
Justin
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Unread 02-19-2007, 01:57 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
Re: Let's see if you can help me... (Motors)
Given the motors you've chosen, I think the most appropriate fix would be a mechanical one. Provide a counterweight or spring to balance the weight of the arm, so you don't have to worry about gravity when moving it.
Unread 02-19-2007, 03:19 PM
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
A counter balance would be best, and you still might want to couple that with a position sensor, such as a potentiometer, and a closed loop position control system. Given that your arm wants to sink to the ground, the control loop would cause apply enough energy to counteract that force and essentially keep the motor stalled to hold the arm in place. This may result in excessive heating of the motor, and subsequent failure.
If you could balance the arm AND provide a closed loop control of the arms position, then it would easily maintain position.
--Dave
Unread 02-22-2007, 08:25 AM
Brian C's Avatar
Brian C Brian C is offline
Chief Cook and Bottle Washer
no team (J-Birds, CIBorgs)
Rookie Year: 1999
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
A "quick & dirty" fix would be to add some surgical tubing on the back of the arm. If you can imagine something sort of like a tendon on your elbow. It takes a bit of tension adjustment but it should help with the tension on the arm.
Cut to size, Beat to fit, Paint to match!
Mentor for teams 1468 & 4006
Unread 02-22-2007, 08:48 AM
mentorDon's Avatar
mentorDon mentorDon is offline
FRC #1764
mentorDon is an unknown quantity at this point
on our arm, we decreased voltage input to the motors when the arm moves down because gravity is doing the work. We also use pots to determine arm position to adjust the voltage depending upon arm angle.
Unread 02-22-2007, 09:04 AM
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
that sounds like a coding problem to me. Since the window motors have worm gears, they should have anti-backdrive, i.e. they should never just fall when you are going down. You should be able to program the arm to go to a certain height and stay there without stalling the motors or anything.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 02-23-2007, 06:42 AM
Unsung FIRST Hero
Broadcast Eng/Lead Robot Inspector
AKA: Big Al
FRC #0111 (WildStang)
Rookie Year: 1996
Justin,
You would think that the motors you have chosen would not back drive but in the configuration you are using them, once they are moving the arm weight will continue the motion. Even if you set the "brake" jumper on your victors, it might not help. Some of the suggestions above will help the situation, I am a big fan of surgical tubing but it might not be suitable for you design. Changing the ratio of the output shaft to arm might also help. I think a combination of a few ideas will solve your problem.
Al
WB9UVJ
www.wildstang.org
________________________
Season Eighteen, what a spectacular year! It's has been a bumpy ride. All is better now, new parts are working fine. Champs were spectacular!
Unread 02-23-2007, 07:52 AM
Cowmankoza's Avatar
Cowmankoza Cowmankoza is offline
KoZa
AKA: Matthew Koza
FRC #1251 (The Tech Tigers)
Team Role: Operator
Cowmankoza has a spectacular aura aboutCowmankoza has a spectacular aura about
Send a message via AIM to Cowmankoza
[quote=richardmcc2;584083]that sounds like a coding problem to me. Since the window motors have worm gears, they should have anti-backdrive, i.e. they should never just fall when you are going down. [quote]
contrary to popular belief, worm gears do backdrive, it just takes a lot more force to do so, and given that it is being used on an arm, it is very possible that it will backdrive
Team 1251 The Techtigers
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award (The real winner)
Offseason Development - Let's see it! sanddrag Technical Discussion 11 07-09-2005 12:23 AM
LET'S GO ARCHIMEDES< SEE YA THURSDAY archiver 2001 0 06-24-2002 02:14 AM
can anybody help me regarding motors? archiver 2001 9 06-23-2002 10:00 PM
Can you find all eleven motors? archiver 2000 1 06-23-2002 09:01 PM
Let's see Chairman's summaries! Andy Baker Chairman's Award 5 04-11-2002 11:32 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
