Go to Post If you cannot complete relatively simple tasks, why would anyone assign you something more challenging?? - Chris Fultz [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 02-19-2007, 07:56 PM
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Sonar Function Issue
I am using the Maxbotics sensor, obtaining data through the AD, and need to find the difference between two consecutive readings. In the following, I have a distance function that returns the distance to the target in inches, and I use that number in the following function delta_distance() to find the difference between consecutive readings.
The problem is, when I run the thing, my return is always the inverse of the actual distance reading, and the issue is, solved with a printf, that my temp variable is never changing. It remains at zero constantly.
Code:
* FUNCTION NAME: distance
* PURPOSE:       returns a realtime distance from sonar, in inches
* CALLED FROM:   This file
* ARGUMENTS:
*     Argument       Type             IO   Description
*    none
* RETURNS:       unsigned int
unsigned int distance(void)
             return (unsigned int) Get_Analog_Value(rc_ana_in01)/s;
* FUNCTION NAME: delta_distance
* PURPOSE:      returns difference in range readings between cycles
* ARGUMENTS:
*    none
* RETURNS:       signed int
int delta_distance(void)
    int temp;
    temp -= distance();
    return (int) temp;
    temp=distance;
As well, if anyone can quickly through up a workable averaging function I'd be much obliged. I've tried without success, typically ending up with a constantly incrementing distance value, or erratic jumping output.
Code:
* ARGUMENTS:
*    none
 unsigned int temp;
 i++;
 unsigned int Distance;
 temp+= (Get_Analog_Value(rc_ana_in01)/2)
 if (i>=5)
          Distance=temp/i;
          i=0;
             return (unsigned int)Distance;
Thanks!
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 02-20-2007, 11:02 AM
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Sonar Function Issue
Team 95 has a huge number of IR sensors (BigHAIR: Big Honkin Array of IR sensors), and we keep time history and a running average on them. Here's a snippet
Code:
long IR_range[6]; // current ranges, generated by another function
long IR_range_history[6][4];  // Last 4 readings, not necessarily in order (see below)
long IR_range_average[6]; // running average of last 4 readings
void Average_IR(void) {
   static counter=0;
   index=counter++%4;  // Keeps from having to copy old data, just
                                 // overwrite one column at a time
   for (i=0;i<6;i++) {
        IR_range_history[i][index]=IR_range[i];
        IR_range_average[i]=0;
        for (j=0;j<4;j++) {
           IR_range_average[i]+=IR_range_history[i][j];
        IR_range_average[i]/=4;
Unread 02-20-2007, 12:39 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
...my temp variable is never changing...
Code:
    int temp;
    temp -= distance();
    return (int) temp;
    temp=distance;
The temp variable in your code evaporates as soon as delta_distance() returns. If you want to keep a local variable's value between calls to a function, you need to declare it static:
Code:
    static int last_distance = 0; // set to zero only on program start, retains value between function calls
    int delta;
    delta = distance()-last_distance; // compute difference between distances
    last_distance = distance(); // remember this distance for next time
    return delta;
SONAR Sensor Software Driver MikeDubreuil Programming 55 03-08-2008 10:03 AM
Maxbotix Sonar Sensor DonRotolo Electrical 17 02-04-2007 11:27 AM
VEX Sonar question Joohoo Programming 2 05-06-2006 12:18 AM
Help with sonar sensor supertw Electrical 3 01-24-2006 10:41 PM
FreeLibrary() Function Raven_Writer Programming 0 08-09-2003 02:39 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
