Go to Post As an adult who has spent years working with youth in Boy Scouts and FIRST, and on behalf of all other adults at the event: deodorant. - Rick TYler [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Chief Delphi Alumni
ADVERTISEMENT
Unread 02-28-2007, 05:02 PM
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Quick & Dirty float to string converter
The following code sample will convert IEEE-754 32bit float/double as used in C18 to a string. There are some limitations, but it runs ok on my unix box. I haven't (and cannot at the moment) try this on PIC18F/RC. The hex binary test values were obtained by creating and populating a float variable under MPLAB and hand copying out the hex value for testing purposes. The unix box is native 64bit, so I may have messed up somewhere but thought I'd drop this 5-minute QnD code out for folks to look at/use if needed or wanted. I'm sure there is a better way, but its just Quick 'n Dirty so don't expect elegant/optimal/all-encompassing.
When run on unix it generates what looks like reasonable output:
alpha> ./printff
1.234567879
1.233999963
1234.000000000
1234567936.000000000
0.123399970
0.001233931
0.000012276
Should work with printff( (long)float-variable-name ).
Bud
PS Derived by reading http://en.wikipedia.org/wiki/IEEE_754
Code:
#include <stdio.h>
int main()
    printff( 0x3f9e0652 );	/* 	f1 = 1.23456789;	*/
    printff( 0x3f9df3b6 );	/*      f1 = 1.234		*/
    printff( 0x449a4000 );	/*      f1 = 1234.0		*/
    printff( 0x4e932c06 );	/*      f1 = 123456789.0        */
    printff( 0x3dfcb924 );	/*      f1 = 0.1234             */
    printff( 0x3aa1be2b );      /*      f1 = 0.001234           */
    printff( 0x374f07e5 );      /*      f1 = 0.00001234         */
void printff( long fbinary )
unsigned char sign;
unsigned char exp;
unsigned long mantissa;
int bits;
long whole;
long fraction;
long left;
    sign = 1;
    if ((fbinary & 0x80000000) != 0) sign = -1;
    exp = (fbinary & 0x7F800000) >> 23;
    mantissa = (fbinary & 0x007FFFFF);
    bits = (int)exp - (int)127;
    if (bits >= 0)
        if (bits <= 30)
	    whole = 0x1;
	    while (bits > 0)
	        whole <<= 1;
	        if ((mantissa & 0x00400000) != 0)
		    whole |= 0x1;
	        mantissa <<= 1;
	        --bits;
            printf( "%c%d.", ((sign == 1)?' ':'-'), whole );
        else
	    // can't do yet
	    printf( "**.****\n");
        fraction = 0;
        left     = 500000000;
        while (mantissa != 0)
	        fraction += left;
	    mantissa <<= 1;
	    left = left / 2;
        printf( "%09d\n", fraction );
    else
        /* Number < 1.0 */
        printf( "%c0.", ((sign == 1)?' ':'-') );
	mantissa |= 0x00800000;
	bits = -bits;
	if (bits < 24 )
	    mantissa >>= bits;
            fraction = 0;
            left     = 500000000;
	        if ((mantissa & 0x00800000) != 0)
	            fraction += left;
	        mantissa <<= 1;
	        left = left / 2;
	else
	    printf( "%09d\n", 0 );
    return;
Unread 03-03-2007, 05:34 PM
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: Quick & Dirty float to string converter
nice job man, im sure it would be useful.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 03-05-2007, 01:59 PM
AKA: Bud
Fixed a couple bugs.
Test cases run:
1.234567879
1.233999963
1234.000000000
0.123399970
0.001233990
0.000012335
0.156250000
98.765434262
9.876543043
0.987654324
Code:
char sign;
unsigned char exp;
int bias;
long data;
long left;
    sign = ' ';
    if ((fbinary & 0x80000000) != 0) sign = '-';
    /* compute whole number */
    bias = (int)exp - (int)127;
    if (bias >= 0)
        if (bias <= 30)
	    data = 0x1;
	    while (bias > 0)
	        data <<= 1;
	        if ((fbinary & 0x00400000) != 0)
		    data |= 0x1;
	        fbinary <<= 1;
	        --bias;
            printf( "%c%d.", sign, data );
        else
	    // can't do yet
	    return;
	/* compute fraction */
        data = 0;
        left = 500000000;
	fbinary &= 0x007FFFFF;
        while (fbinary != 0)
	        data += left;
	    fbinary <<= 1;
	    left = left >> 1;
        printf( "%09d\n", data );
    else
        /* Number < 1.0 */
        printf( "%c0.", sign );
	bias = -bias;
	if (bias < 24 )
            data = 0;
            left = 500000000;
	    fbinary &= 0x00FFFFFF;
	    fbinary |= 0x00800000;
	    fbinary >>= (bias-1);
	        if ((fbinary & 0x00800000) != 0)
	            data += left;
	        fbinary <<= 1;
		left = left >> 1;
	else
    return;
PS I'm not trying to encourage the use of floating point, but for debugging and in small doses it has its uses.
Robots that float boy_scout72688 Rules/Strategy 31 01-15-2007 09:18 PM
Float Design i like dirt Technical Discussion 3 09-12-2006 11:21 PM
Float in MPLAB capenga Programming 1 02-18-2005 05:44 AM
is string legal? Jeremy L Kit & Additional Hardware 7 03-07-2004 03:28 PM
Q&A Discuss: Quick C Programming Q CD47-Bot Extra Discussion 6 11-16-2003 10:16 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
