| View Poll Results: Are you going to be affected if @Home goes under? | |||
| Yes |
7 | 25.00% |
| No |
21 | 75.00% |
| Voters: 28. You may not vote on this poll | |||
The vultures are circling around @ Home
I don't know if you don't know, but this article will tell it all.
http://www.techtv.com/money/business...343410,00.html @Home doesn't even know if it going to make it through the year. That is going to be a big disappointment to a lot of people. Because @Home most of the times is the cheapest High-Speed Internet around there. This is like the big DSL fiasco earlier this year that disconnected a lot of users. If @ home doesn't survive, than the cable companies will chose a service that is probably going to be more in price. I know a lot of people have @Home and this is a serious problem. I am just hopping for the best, and @Home will beat this problem. |
dude, that isn't even cool!! i had no idea that they were even having problems. if they go out of business me and a bunch of my friends are going to be VERY disappointed. it's a pretty good service, although we've had some connection problems recently here in Indy. I have no idea of what to do if this happens. thanks for the info Kyle. i'm gonna have to keep an eye on this.
It'll work out
That is the main reason AT&T is trying to sell its "broadband" division. Whomever purchases it will get the entire package: cable internet and television. It'll all work out, unless AOL/TimeWarner places the winning bid (AOL/TimeWarner and ComCast are the most interested companies)..
Why won't it work out if AOL makes the winning bid?
I didn't even know what @Home was before I read that article. I just use 56K, so..yea..my house won't be affect. Now, if BellSouth suddenly went out of buisness, I wouldn't have I-net or phone service. Not fun.
~Angela who still doesn't get why IRCCNet uses BellSouth to actually provide it's I-net service |
Broadband internet as whole is not really a good commodity because the general public doesn't see the need to spend $35 to $50 for internet + the $100 to $200 cable/DSL modem. There isn't a great need to go out and get high speed internet service becuase they feel it isn't neccessary. Most people don't download video clips or flash clips like some of us do. You see, the way to get more broadband customers is to make it a need to get around in life. Until then the most an average person would pay is the $21.95 AOL fee a month.
Matt who's happy that he'll be on Road Runner in a few weeks ![]() |
Unfortunately dsl isn't available anywhere, but I definately recommend it for those who can get it |
Today's engineering lesson
The reason for this is due to the nature of digital data. A digital signal takes up a wide array of frequencies, with the width corresponding primarily to the speed of the signal. If you tried to transmit data at a higher speed than what a line is designed for, some of the higher frequencies would be attenuated, and you would start to get a lot of errors. |
#10
Re: Today's engineering lesson
Matt |
#11
But higher frequency means higher bandwidth, in most practical cases. DSL doesn't just use some high frequency 'f' it uses the range of freqencies from 0 to 'f' (or from some other lower frequency to f). If DSL could only use one frequency (a very narrow band signal), it would only be able to broadcast a continuous sine wave, which, by itself, could carry no information. Once you start turning the sine wave on and off, in order to transmit some data, the band needed starts spreading out, and if you want to have high-speed data, then you have a broadband signal.
Likewise, an FM radio station has more frequency space available, not due to nature or physics, but because the FCC licences FM stations 200kHz apart (which is why some digital radio tuners only up and down by 0.2MHz), while AM stations are licenced only 10kHz apart. That means that audio frequencies above ~5kHz have to be filtered out of the AM station's broadcast signal before it's transmitted, while FM stations can keep frequencies up to 15kHz (I think). |
#12
The reason having a larger range of frequencies available for transmitting increases the bandwidth is primarily because it increases the number of channels for transmission. The spectrum of available frequencies is divided into multiple channels and each channel can sustain a certain transfer rate; adding more channels increases bandwidth. It's important to remember that just because something's broadband doesn't mean that it will have a higher transfer rate than something that is narrowband. The word broadband has begun (incorrectly) to refer to high bandwidth which is unfortunate because they mean different things. Matt |
#13
Here is another article that says @Home owes 50 million dollars or the mortgage company will push them into bankruptcy.
http://www.techtv.com/money/business...344550,00.html |
#14
I stand corrected.
And as far as this: Quote:
:) Last edited by Kris Verdeyen : 08-29-2001 at 01:12 PM. |
#15
I know this an old thread, but this article indicates that @ home is dead in the water
http://www.nytimes.com/2001/09/29/te...gy/29EXCI.html Chapter 11 |
| When the regional is close to home | Alfred Thompson | Regional Competitions | 8 | 12-17-2002 12:39 PM |
| Mt Home Arkansas | archiver | 2001 | 5 | 06-24-2002 03:14 AM |
| Mountain Home & 'The Brawl' | archiver | 2000 | 0 | 06-23-2002 10:20 PM |
| To all those watching from home... | archiver | 2001 | 0 | 06-23-2002 09:16 PM |
| Taking the kits from Manchester on planes back to home base | Ken Leung | General Forum | 4 | 09-24-2001 09:47 PM |
