Go to Post Have we all said "thank you for all you do" lately? :) - RoboMom [more]
Go Back   Chief Delphi > Other > VEX
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
Chief Delphi Alumni
ADVERTISEMENT
Unread 04-03-2007, 04:21 PM
Engineer at iRobot
AKA: Dr. Joe
FRC #3958 (FRC Teams Need Names?)
Rookie Year: 1996
Help Getting Started with VEX programming.
Hi All,
I own an early VEX kit from before they were programmable. It has been a while but I am finally to the point that I would like to try out some of the programming aspects of VEX but, frankly, I don't know what I need to get started.
I am thinking I will want to try EasyC not because I can't do C/MPLAB but because I was impressed with the work I saw some kids on Chief Delphi's team did with their FIRST robot and I thought I would like to see what are the limits/capabilities of the software.
So... ...what do I need and where can I get it? If software/hardware is required does anyone have a setup they are willing to part with cheap?
Thanks in advance for the help.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
A rookie again after all these years...
Unread 04-03-2007, 04:28 PM
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins Send a message via Skype™ to EHaskins
Re: Help Getting Started with VEX programming.
You will need a VEX programming kit. It comes with EasyC for VEX. It is available from www.vexlabs.com for $99.99.
EDIT: EasyC for VEX is significantly more limited than EasyC for FRC/Easyc Pro. This applies to EasyC Pro in Vex mode also.
If you really want to test the limits of EasyC for FRC applications then you really need to use a full size robot.
EDIT again: The VEX programming kit includes a USB>serial cable, VEX programmer(hardware), programmer>VEX cable, and EasyC.
Eric Haskins KC9JVH
Unread 04-16-2007, 05:50 AM
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
easyCPro for VEX has 100% the same feature set as for FRC.
Joe, I would recommend starting with the getting started guide in the help file. There are 12 step-by-step tutorials that should get you going programming your VEX robot. Also, we gave out one free copy of easyCPro to all the FRC teams if your team didn't use it you can use that to program with your VEX robot.
Intelitek Support
[BFIRST Team 146 Blue Lightning - Alumni[/b]
FIRST Team 40 Checkmate
Unread 04-16-2007, 06:39 AM
gblake's Avatar
gblake gblake is offline
5th Gear Developer & Mentor
AKA: Blake Ross
VRC #0042 (Mostly Harmless)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
There has to be more to the story than simply sitting down with a copy of EasyC Pro... What options have to be changed? What libraries have to be referenced? Which templates do you use? Does EasyC Pro come with a cable(s)+"dongle" that works with the Vex Microcontroller?...
Is every bit of this in those tutorials (are they Vex-oriented tutorials or generic EasyC Pro tutorials) and any other items supplied with EasyC Pro?
Blake
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Unread 04-16-2007, 07:56 AM
Kingofl337's Avatar
AKA: Adam
Rookie Year: 1998
In easyCPro we made all the features avalible from the FRC library for Vex.
All you have to do is goto Robot controller setup and switch to VEX
Features include but are not limited to.
- Quad Encoders
- Gear Tooth Sensor
- CMU Cam
- Interrupt Watcher
- Analog Devices Gyro 80,150,300 Deg/sec
- Accelerometer
- 'C' Syntax Editor
- Initialize in Competion Templates
- Ability to Name Your Ports
- Case-Switch Commands (Though this may be added to V2 soon)
No extra programming cable is required and you wire the sensors the same as your would on the FRC robot except the camera which I have made a diagram on how to use it.
http://www.chiefdelphi.com/forums/sh...ad.php?t=52573
Intelitek Support
Unread 04-16-2007, 08:01 AM
AKA: Eric Haskins
EasyC Pro does NOT include the hardware to interface with VEX. If you buy the VEX programming kit you will have everything you need to get started.
The tutorials included with the VEX programming kit are VEX oriented.
You can read the Programming section of the Inventor's Guide here(PDF).
Eric Haskins KC9JVH
Programming - Getting Started Mark McLeod Programming 80 04-16-2008 10:37 PM
Problem getting started with USB 6009 JimGRobot LabView and Data Acquisition 1 12-18-2006 08:15 AM
Getting Started with Scripting LBK Rules Programming 2 01-15-2005 12:28 AM
Programming and Electronics — Getting Started Sidney San Martín Technical Discussion 7 01-12-2005 02:25 PM
Help needed for getting started! chantilly_team Programming 4 10-27-2004 07:29 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
