pic: Planitary Transmission
Re: pic: Planitary Transmission
It looks great.
Can you give us some more details about it? Sizes, Forces etc.. |
looks like it could be a great transmission if it is geared to the wheels correctly. love the design, great work man.
It's true that the ND motor cannot be backdriven, but you may face another problem. The gear inside the ND is plastic and in high-torque applications (such as a drivetrain) it has been known to strip. I don't know what forces you're putting on it, or exactly what would be enough to destroy the motor, but be careful. Prolonged use, even below the actual stall torque of the motor, can wear down that gear.
Is there any chance you could explode this assembly or provide some better explanation of what it does?
I'm curious as to how you plan on attaching that back plate to the motors...
Other than that, looks like a solid starting base! |
Back plate looks easy, probably just some holes for the super long screws that hold the CIMs together. Dunno if that's legal or not but that's how I'd do it. I'd be more concerned about the planetary assembly itself. With all the elements on bearings, I think you'd need to plan for a little more backlash than usual to account for extra play from the bearings.
Re: pic: Planetary Transmission
I like the idea, but I would never put the Denso motors in a drivetrain. Even though the worm inside the motor is metal, the gear is fairly soft plastic and strips way too easily.
If you want to make your tranny anti-backdriveable (sp?), I would recommend that using a wormgear other than the one in the Denso. |
Love the work and wish I had some ability to design drive-train transmissions. |
#10
I believe that the denso worm gear would see relatively little torque because it is just modifying one part of the planetary gear train that is normally stationary. Precession and procession modify the gear ratio. Can you show the exploded view of the planetaries?
#11
I GET IT!!
I have been looking to do the same thing for a while. Its sort of a constant velocity transmission. But teh Denso motor won't really allow uch variation. Consider this. Use to motors, on on the hub and one driving the outer ring. I agree that you will have to put some current thru the outer ring when running just the hub but the payoff is many different ratios Nice cad work |
#12
I know that the ND motor won't allow much variation but it is some and it does add to the output force so I think i could gear this a little higher if I wanted to.
I would be gearing the output shaft directly to a set of 6 inch wheels since the reduction through the trans is high. Meaning if the robot was pushing an object with 200 pounds (something that I have seen FIRST bots do) it would produce 34 Nm of torque on the output shaft. There is a reduction to the ND motor of 3.67:1 which means that everything at stall there would be 9.2 Nm of torque on the ND motor which is less than the motors stall torque. As said by many people this is not an optimal solution but it is the easiest thing to machine. A major part of the box was that it was easy to machine and assemble. All the parts can be made on a small CNC mill with limited skill or on a small lathe. These two things make a worm gear hard for a more powerful motor. In any case the output rpm of the ND motor is 84 rpm and with a reduction of 3.67 the change in output speed of the output shaft is ~45 rpm which translates to a speed difference of 1.18 ft/s so it varies from 7.55 ft/s to 8.73 ft/s which isn't a big difference but... I will post a pic of the planetary showing the inner workings and a pic of a chassis that it could work with. Thanks for all the compliments. Alex |
#13
I would be cautious about using the long screws in the CIM motors to mount a back plate. Once you take them out, it can be exceedingly hard to get the screws back in, due to all the magnets inside the motor. I've trashed a CIM before doing that, and I know a few other people have done similarly.
| pic: 379's transmission | Robo_Cat_379 | Extra Discussion | 10 | 03-05-2007 07:48 AM |
| pic: 2 Speed Transmission | AustinSchuh | Extra Discussion | 20 | 12-30-2006 03:39 PM |
| pic: 2 speed transmission 1 | psyco_klown | Extra Discussion | 3 | 09-05-2006 06:03 PM |
| pic: 2 speed transmission 2 | psyco_klown | Extra Discussion | 0 | 05-22-2006 12:35 PM |
| pic: lego Planitary... Kinda | CD47-Bot | Extra Discussion | 5 | 07-14-2003 10:55 PM |
