Go to Post The fact of the matter comes down to this: No matter what you are interested in, you can always encourage others. - Amanda Morrison [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Cross the Road Electronics
ADVERTISEMENT
Unread 12-02-2007, 04:30 PM
OneCoolDude OneCoolDude is offline
OneCoolDude is an unknown quantity at this point
Programming help. EasyC Vex Robot.
FIXED
Unread 12-02-2007, 04:45 PM
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Re: Programming help. EasyC Vex Robot.
The first thing I would look at the configuration of the analog/digital ports and whether or not you have the cables plugged in correctly. Take a look at the ultrasonic help page in EasyC and make sure everything is set up properly first.
Unread 12-02-2007, 04:54 PM
Wow, It was a D'uh problem. I wrote 2-3 other programs on EasyC, and I thought it would just keep the same controller config. But it didnt, and I fixed it, and the ROBOT WORKS!! I am so exicted. But if anyone has any advice on the program to make it better, I will gladly take some.
Need help with ramping in VEX EasyC T. Maty easyC v2 for Vex 4 11-03-2006 11:17 AM
Arrays in Vex Programming Kit EasyC? gblake FIRST Tech Challenge 9 09-12-2006 04:05 PM
Help needed with coding simultaneous movement (EasyC/VEX) bodaciousllama Programming 7 08-14-2006 04:35 PM
EasyC-Vex Rx/motor frustrations- please help! Steve0100 Programming 10 07-08-2006 01:18 AM
White Paper Discuss: VEX / intelitek easyC programming document dez250 Extra Discussion 3 09-15-2005 02:20 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
