Go to Post I say we all stop flaming and pointing out what went wrong or what bad calls were made and start pointing out how much fun we all have at the regionals and what FIRST actually has done for us. - burkechrs1 [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
OLHSA
ADVERTISEMENT
Unread 12-08-2007, 09:12 PM
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
Team Role: Leadership
Rookie Year: 2007
team2061 will become famous soon enoughteam2061 will become famous soon enough
NED HELP ON BUILDING 1 OR 2 SPEED GEARBOX
I NEED HELP ON HOW TO BUILD A VERY EASY SIMPLE AND CHEAP GEARBOX FOR 2 CIM MOTORS. THEY CAN EITHER BE 1 OR 2 SPEED GEARBOXES W/ PNEUMATICS SHIFTER.PLEEEEEEEEEEEAAAAAASEEEEEEEEEE HELP.
Unread 12-08-2007, 09:20 PM
EricH's Avatar
EricH EricH is offline
...has read the 2012 Manual
FRC #0330 (Beach'Bots)
Send a message via Skype™ to EricH
Re: NED HELP ON BUILDING 1 OR 2 SPEED GEARBOX
Why build when you can buy? http://www.andymark.biz/ has gearboxes. Maybe you can get plans from them, or just the gears and make your own box.
Build a cheap gearbox--ouch. You'd need at least a manual mill. Then the material for the sideplates and axles. Then the gears and output sprocket. Assuming you have the mill, you'd be looking at at least a couple hundred, I think. That's about what an AM gearbox costs.
Paths a rules question takes:
Official: Post to Q&A-->GDC reviews-->Official answer posted on Q&A.
Unofficial: Post to CD-->CD views and comments, sometimes using The Manual and interpreting it-->Somebody goes the Official route -->Answer gets posted on CD eventually, as a quote from Q&A.
Which one takes longer for an official ruling? Therefore, which one makes more sense to use?
Unread 12-08-2007, 09:36 PM
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Yeah, AndyMark is going to be nearly impossible to beat, price wise. You may be able to build a two speed crash shifter for less than $300, but it'd be pretty close. A single speed could also be built for around $70, which is only like $20 dollars less than an AM single speed. In both cases, you'd be spending a significant amount of time doing the machining and you would have to live with the possibility that the transmission not work properly.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
team2061's Avatar
Gilberto Gonzalez
Rookie Year: 2007
MY TEAM WOULD LIKE TO BUILD SOMETHING LIKE THIS BUT DONT KNOW HOW?? DO YOU KNOW WHAT THE ORANGE THINGS ARE THAT ARE CONNECTED TO THE CIM MOTORS? WHAT IS THE THING IN THE MIDDLE BETWEEN THE TWO CIM MOTORS?
http://www.chiefdelphi.com/media/img...478aa6d3_l.jpg
Unread 12-08-2007, 09:42 PM
in between teams
AKA: Luke Van Oort
The orange things are some sort of shaft coupling, and the black thing is probably an optical encoder
Unread 12-08-2007, 09:47 PM
EricH's Avatar
That particular gearbox seems to be a means of connecting two CIMs to the same planetary gear. Not sure which team built it, but they could probably give you an estimate of cost.
P.S. Could you turn caps lock off? Having it on makes it sound like we're being shouted at.
Unread 12-08-2007, 09:50 PM
team2061's Avatar
Gilberto Gonzalez
Rookie Year: 2007
im soory i guess i got used to typing in caps lock, but i no longer will.=)
Unread 12-08-2007, 09:53 PM
team2061's Avatar
Gilberto Gonzalez
Rookie Year: 2007
im sorry you guys but im very new to this. what is a shaft coupling and an optical encoder??
Unread 12-08-2007, 10:09 PM
in between teams
AKA: Luke Van Oort
I don't think that that is a planetary, it looks just like a very large one-stage spur gear reduction.
A shaft coupling is something that attaches to two shafts and locks them together so that torque can be transferred from one to the other.
At its most literal meaning, an optical encoder is something that uses light to 'encode' something into a form readable by a computer. In this case, it takes rotation on its shaft and outputs a pulse of electricity every time the encoder shaft moves a certain number of degrees. To find out more about encoders, read this.
Unread 12-08-2007, 11:00 PM
EricH's Avatar
I'd say planetary because it'd be pretty hard to get the reduction from a CIM in ONE stage by means of a spur gear.
One thing that could make life easier is a link to the picture in CD-Media, not just the picture alone. (Couldn't find it by searching; trying again now.)
Unread 12-08-2007, 11:35 PM
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Those orange pieces are Lovejoy shaft couplings. They can be found here
I used these pretty extensively when I was on 100. They are very nice as far as shaft couplings go. They have a flexible rubber "spider" that sits between the two coupling pieces that allows slight misalignment of the two shafts. They worked extremely well in my experience. The only downside is that they are HEAVY. If you use anymore than a few, the weight will add up very quickly.
*2001-2004: Team 100
2005:
*Sacramento-Inspector/Referee
*UTC-Field Reset
*SVR-Inspector/Referee
*Nationals-Inspector/Referee
2006-???: Mentor, Team 254
Unread 12-09-2007, 01:35 AM
gburlison gburlison is offline
Mentor
FRC #0662 (Rocky Mountain Robotics)
Rookie Year: 2000
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
This gearbox has a 16 to 1 ratio using 5 tooth stem pinion gears on the CIMs and a 80 tooth spur gear on the output shaft. The use of a stem pinion gear requires a coupler since it is too small to fit on a CIM shaft.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 12-09-2007, 01:39 AM
EricH's Avatar
Makes more sense. Is that one of yours, or did you just analyze it to death?
Edit: Yes, it is 662's 2007 robot. The discussion and original picture are here.
Edit2: Did you guys run into any issues? How much did it cost? What other info would help this team?
Unread 12-09-2007, 02:03 AM
Mentor
Rookie Year: 2000
Team2061 sent me a PM and I provided him more details, but the short answer is that it cost about $100. It is a simple one stage gearbox using the smallest stem pinions we could find (5 tooth) and the biggest spur gear practical (80 tooth). There is one main issue with this gearbox and that is alignment. The output shaft is supported in three bearings, so misalignment can cause binding. The first year we built this design, we used solid couplers on the CIMs and this also suffered from misalignment and binding. The Lovejoy Couplers took care of any possible binding of the stem pinion gears. Just for reference, this is our first Gen of this Gearbox. http://www.chiefdelphi.com/media/photos/19829
  #15   Spotlight this post!
Unread 12-09-2007, 02:07 AM
Tom Bottiglieri Tom Bottiglieri is offline
Custom User Title
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Send a message via AIM to Tom Bottiglieri
My recommendation would be to purchase one of the previously stated boxes. Take it apart, study it, and learn how everything works. Take what you've learned, let it ferment for a few months, then put that knowledge to good use next season designing your own.
pic: 114 2 speed Gearbox CraigHickman Technical Discussion 13 02-25-2007 06:41 PM
2-Speed Shooter Gearbox JVN Technical Discussion 4 02-08-2006 12:52 PM
pic: Vex 2-speed gearbox crazykid234 Extra Discussion 3 01-03-2006 07:18 PM
TechnoKats 2-speed gearbox ebenhopwil Technical Discussion 17 06-27-2004 01:06 AM
pic: dual speed gearbox CD47-Bot Extra Discussion 9 10-07-2003 02:04 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
