| Thread Tools |
Rating:
Display Modes |
#151
Re: pic: Game hint
I am guessing that there will be stations around the field that give data to the robot.. And the robot has to carry that data to another station..
Or maybe the IR stations would tell the robot which side of the field they need to score in? Which goals to use? That would be cool.. Imagine if each team was assigned a color during autonomous mode via IR blasters?! And the robot had to interpret this!! ::edit:: I really like this guess Post 108 I would love to see the human player able to manipulate the field with a remote! ::::::::: Maybe.. I just hope that the game doesn't require constant use of the IR sensor.. If they do, everyone in the audience will bring their TV remotes from their hotels! On second thought, the clues are never 100% accurate.. So maybe it just has to do with HEAT.. IR senses heat (it is heat!).. So let's just assume the game has to do with heat.. Flamethrowers anyone!? Giant incinerators!??!? WEIGHTED COMPANION CUBES!!!!! ![]() ![]() Last edited by neutrino15 : 12-16-2007 at 01:33 AM. |
#152
Re: pic: Game hint
I think the use of coding is intended to help reduce inadvertent interference like that from the video cameras. But that still doesn't deal with reflections and an object does not have to be shinny to be a good IR reflector. The only way to prevent reflections from being an issue is to not give those photons anything to hit. |
#153
Re: pic: Game hint
My best guess is the possibility of the IR sensors receiving the value of the colored light (red, green, or blue). However, correct me if I'm wrong, but it is possible to look for all three colors with the CMU camera without too much of a problem...
Please everybody keep in mind that these are sensors, not transmitters... they receive. not get. |
#154
Re: pic: Game hint
yes the S1 element is 100%(or at least 99.999995%) an IR receiver, Ive built too many LIRC circuits to not recognize that thing. Im guessing this will be used as a way for the robot to communicate with the field(2way) or for the robots to communicate with each other(again 2way). again this is why I love this time of year eggnog, colorful lights in the house(both of the visible and non flavors), and hints about what Im going to be spending every spare second thinking about for the next 2 months.
#155
Re: pic: Game hint
I think this will take the place of the radios.
#156
Re: pic: Game hint
Wow...Im just now seeing this. From this point on the days are going to become very long.
#157
Re: pic: Game hint
Official word says that Israeli teams will only get this at the kickoff.....
![]() This should help you on the speculating side I guess... It can't be that critical to send it out early if the ~40 teams here don't et it till the kickoff... -Leav |
#158
Re: pic: Game hint
I doubt it.. IR needs a line of sight connection.
Re: pic: Game hint
Random active goals on the field?
#160
Re: pic: Game hint
Wow, what a crazy game hint. I'm the alternate contact and shipping contact for 2158, and I didn't get any official email from FIRST
I think I'll be checking my mail all day on Monday though to see if I get anything in my mailbox ![]() |
#161
Re: pic: Game hint
Did they really expect all the teams to program the CMU camera? |
#162
Re: pic: Game hint
As far as this little baby's use for this year. First, the operating voltage range is 7-15 VDC. Its definitely an onboard robot device. 7.2 volts = backup battery supply just like CMU and servos, but can also operate at 12 volts just fine so it can be used off main battery source. Also, since FIRST is giving specific idle and in-use power consumption data, this is for your power budget folks! A benchtop power supply isn't going to worry about consumption much. My vote is onboard robot and connected to backup battery circuit, and you'd better watch power consumption especially if this is being used with a CMU and/or servo pan/tilt mechanisms. The device can receive four different signals, and has an input acceptance angle of +/-30-40 degrees. This is important! Also, the further off axis the sensor is the weaker the signal will be. Will this employ a reliability threshold like the CMU does? I suspect this could be used for navigation purposes, probably in autonomous. If a device like this were mounted on a pan/tilt a robot could sweep the sensor around and pick up four discrete signals from the playing field, and using servo feedback, could navigate with some reasonable reliability other than the reflection issues. Another possibility, might not be navigation due to the IR reflectivity noted above, but simply to allow the robot to decide on which field orientation it should face. Four input signals = two endzones + two sidelines. Perhaps robot orientation has something to due with scoring or where to score the most points? Time to mull this over some more.... ![]() |
#163
Re: pic: Game hint
i think first will take advantage of this some how
so you have to get right up to the goal ?? |
#164
Re: pic: Game hint
and doesn't this mean no more ir flash on cameras
if you ever staffed a fll comp you know what i mean |
#165
Re: pic: Game hint
The thing receives a coded series of blinks from an IR emitter. It isn't a simple on/off detector like the 2004 sensors. For the same reason your TV doesn't change channels if you take a picture of it, this will not care if someone makes an IR emission it is not trained to recognize.
| pic: 2007 Game Hint? | dlavery | FRC Game Design | 161 | 01-07-2007 12:42 PM |
| pic: 2007 Game Piece Hint | Wetzel | Extra Discussion | 39 | 01-06-2007 11:24 PM |
| Offical Game Hint! | Greg Needel | Rumor Mill | 117 | 12-21-2006 03:25 PM |
| dlavery game hint | nuggetsyl | Rumor Mill | 173 | 12-20-2006 09:00 PM |
| Game hint?!?! | Andy Grady | Rumor Mill | 67 | 12-30-2002 05:15 PM |
