| Thread Tools |
Rating:
Display Modes |
#421
Re: New C18 3.0+ Compatible FRC Code
Now that you mention it, the battery was at 8.2 V
No, really, we always had a charged battery and the 8.2V bug never appeared to us. |
#422
1) Use the DEBUG() macro (see ifi_frc.h) so that it's easy to remove the printf() statements from your competition code. 2) You can also redirect the output to go nowhere by placing this line in teleop.c/Initialization: stdout_serial_port = NUL; This will prevent the stalling, but isn't optimal because the code associated with printf() will still execute. 3) Increase the RX1 buffer size in serial_ports.h to 64 or even 128 bytes. I've also seen a few inconsistances in your code. Can you describe the 'bot a bit? I'm mostly interested in the sensors you're using and how they're attached to the robot controller. -Kevin Last edited by Kevin Watson : 03-07-2008 at 11:03 AM. |
#423
Our issue was a bad RC. We swapped a loaner in this morning and everything has worked fine since. Our inability to reproduce the error made it really hard to diagnose, but we finally traced the problem to cold booting the RC (cold booting was causing the program to become corrupted).
Kevin - Thanks for taking the time to look at our code We're now running a kit gyro with your gyro driver and a pot (which is used to control the direction our steerable front wheels are pointed).Thanks for the help everyone, and watch out for defective RC's. |
#424
)We used Kevin's beta 3.0+ code (as of 2 Feb 2008) with the following features / modules:
All of the above worked beautifully! Autonomous modes on both robot configurations behaved very well, and we never had any troubles that we can attribute to Kevin's code. (We did, of course, have our share of problems, including tracking down a flaky magnetic encoder, our own bugs in our own code, and an IR board that lost its programming before our last qualifying match.) Thanks, Kevin, for all of your work on the "new and improved" FRC code! |
#425
-Kevin |
#426
This new code is a wonderful improvement. I especially like its straightforward approach, and simplified way of inserting mission-specific code. It has been a joy to use. But there's still something I'm trying to figure out about it, so if anyone can help, I'd be grateful...
It started with trying to figure out something unexpected which happens when we hold down the "Disable" button on our competition port dongle while booting the RC. In the function main() in ifi_frc.c, the one-time initializations occur of couse, and the "while (TRUE)" loop is entered, but to our surprise, we see "Teleop_Init()" execute, where we would have expected "Disabled_Init()" to be chosen instead. Now the first thing inside the "while (TRUE)" loop is the test "if (disabled_mode)...", where disabled_mode is a field inside rxdata. But I don't see where rxdata has been set at this point. It appears to be set later on through calls to Getdata(&rxdata), once statusflag.NEW_SPI_DATA becomes 1. Could someone enlighten me as to what I'm missing about the initialization of rxdata, specifically fields disabled_mode and autonomous_mode? Or is this, like, maybe a problem? If you've read this far, thanks, but while we are in this vicinity, I also have a question about "statusflag.NEW_SPI_DATA", which before the "while (TRUE)" loop is set to 0. I assume it is really "volatile" even though I can't find that in any of its declarations (again I'm missing something?), but if it isn't 1 by the time we go through that loop the first time, wouldn't a _Spin() function be called before its corresponding _Init()? Is there some mechanism preventing this, or do we need to take this possibility into account in programming the _Spin() functions? Anyway and everyway possible, Kudos to Kevin, he has made our world more enjoyable through his efforts! |
#427
Code:
statusflag.NEW_SPI_DATA =0; while(statusflag.NEW_SPI_DATA ==0); while(TRUE) |
#428
... And, once NEW_SPI_DATA becomes set, is a Getdata() call also needed, so that disabled_mode and autonomous_mode become set based on the contents of the newly-arrived packet?
#429
We ran your code successfully at the San Diego regional.
#430
Kevin...
Team 812, The Midnight Mechanics from the Preuss School at UCSD used you code as the basis of there robot for the San Diego regionals and the team received the Chairman's Award. Thank you very much for your contribution to the First Robotics Program. |
#431
Kevin,
Just to add to the positive feedback, team 435 used your new code this year. (I think we are at least one version behind.) We had no problems which you have not already fixed. In addition to the base 3.0+ compatible code, we also used the EEPROM, tracking menu, and portions of the robot.c code from previous years. The structure and starting sensor code has clearly been a great boon to the team's development of both teleop and automonous code. So please take this as another great big thank you from another appreciative team. Rich Daugherty Programming Mentor - Team 435 RoboDogs SE Raleigh High School - Raleigh, NC |
#432
-Kevin |
#433
does anyone know a site were i don't have 2 download anything to see the new code, because im at school and they won't let me save the kind of files that r posted on kevin
thnxs in advance if you know the site just message me thnxs again Last edited by XXShadowXX : 03-13-2008 at 12:18 PM. |
#434
In the end, it wasn't my code's fault, neither Kevin's (obviously ). Great when you can blame the other guy for the hardware, heh? |
#435
| Does the camera code suits to all versions of MPLAB and C18? | razer | Programming | 3 | 01-04-2007 01:50 PM |
| Trying to follow C18 interrupt context code... | dcbrown | Programming | 5 | 12-21-2006 08:01 AM |
| Error w/ FRC code | JamesBrown | Programming | 2 | 01-08-2005 03:17 PM |
| Programming code Fix FRC | Ferazel2001 | Programming | 6 | 02-08-2004 01:46 AM |
| FRC default code | hedgehogger | Programming | 2 | 01-21-2004 05:41 PM |
