Go to Post Minus the one time when our Autonomous mode actually reversed, ran into the robot behind us, and lodged them into the rear wall - MysterE [more]
Go Back   Chief Delphi > Technical > Control System > IFI Control System
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Caroll Turpin
ADVERTISEMENT
Unread 01-09-2008, 08:45 PM
Tanis's Avatar
Tanis Tanis is offline
Smoke monster
AKA: Bryan
FRC #2052 (KnightKrawler)
Rookie Year: 2007
Tanis is a glorious beacon of lightTanis is a glorious beacon of lightTanis is a glorious beacon of lightTanis is a glorious beacon of lightTanis is a glorious beacon of lightTanis is a glorious beacon of light
Need tips on wiring the IR board
Hey guys, we started hooking up the IR board yesterday, and are looking for a bit of help.
We got all the appropriate wires connected, but rather messily. We soldered the pwm cables and battery wires to the appropriate pins using the ribbon cable, but... The pwm cables are about twice as large as the ribbon, cables, and theres one wire on the pwm cables that is unused (white wire on each pwm cable connects to one each of the signal outputs, each black is connected to common ground, red is hanging there). The battery wires are enormous compared to the ribbon cable (using standard backup battery + wires).
We currently have a bunch of wires going all over the place, of which all connections are soldered together then electrical taped.
Did we do this right, and is there some way to clean it up?
I'll hopefully get a picture of this tomorrow to help.
2007-Present: Team 2052- Knightkrawler
2010: Dean's List finalist
2011-2013: Mentor, inspector, field supervisor, President of GOFIRST at the University of Minnesota
Unread 01-09-2008, 09:08 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
Re: Need tips on wiring the IR board
You can "cheat" a little and use only two PWM cables. One of them will have the black and white wires for ground and one signal, with the red +5 unused. The other will carry the remaining three signals, and plug into the Robot Controller "sideways" across where the white pin of three connectors would usually go.
If we use the IR detector board, I intend to make a small "wiring concentrator" board to go next to it. All the digital input and power connections will go to that board, which will have a ribbon cable connector to bring all the signals to the matching connector on the IR board.
Unread 01-09-2008, 09:14 PM
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
What we did was wire the power and ground to the fuse board exactly like the RC itseld, then just connected each signal wire to a signal port on the digital inputs. It works (for now)
Unread 01-09-2008, 09:27 PM
sayso_411's Avatar
sayso_411 sayso_411 is offline
10 Years of Sparky!
AKA: Shaav
FRC #0384 (Sparky)
Rookie Year: 2007
sayso_411 can only hope to improve
We hooked up everything correctly and programmed the robot to do simple functions but i m skeptical how RoboCoach is going to effect the game this year
Unread 01-12-2008, 05:34 PM
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
This may help:
http://www.chiefdelphi.com/forums/sh...12&postcount=4
What place are we at? ... TODAI!
pic: Team 668 Wiring Board burkechrs1 Extra Discussion 4 02-06-2007 12:56 AM
I need the 2006 Wiring Schematic Diagram SkD_nub Electrical 2 02-06-2006 01:46 PM
New at this and need some helpful tips Nathan B. Technical Discussion 5 01-06-2005 08:04 PM
need some help with the OI, and wiring a display pryoplasm IFI Control System 8 03-10-2004 07:46 PM
I need tips on Starting a New Team. Rook Starting New Teams 6 03-25-2003 10:19 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
