Go to Post So I guess this is just another case of someone reinventing the leg? - petek [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Chief Delphi Alumni
ADVERTISEMENT
Unread 01-11-2008, 11:34 AM
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #2062 (C.O.R.E.)
Rookie Year: 2000
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
Good connector for IO AMPMODU
We started using the AMPMODU series of connectors for wiring our sensors to the robot controller. For a PWM, DIO or analog input you can use this connector.
The crimper is expensive, but with a small pair of pliers and a steady hand you can attach the contacts to your wire. We use 2,4 and 6 conductor wire (22-24G) from Home Depot. It is stranded and robust enough for use on the robot. We touch a bit of solder to the wires to make sure the contacts don't come off.
Using this system we made wire harnesses for the IR, gryos and gear tooth sensors. The contact can be easily removed from the housings using a sharp object and reinserted (good for fixing pins out of order on the IR board!).
Of course you can sacrifice PWM cables for connection to your sensors, but that approach also gets expensive.
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
what is the four pin white connector for on the ir board ? Smaug Electrical 2 01-10-2008 10:37 PM
Connector for gyro chip MarkVH Electrical 11 12-22-2005 10:59 PM
power connector for 2004 EDU controller kc8nod Robotics Education and Curriculum 6 11-25-2003 03:59 PM
Electrical Connector For Climate Control Actuator gail OCCRA 3 10-20-2002 10:20 PM
FIRST -- good for mind, but not for ears archiver 1999 7 06-23-2002 09:14 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
