Go to Post Don't just build a robot; build up your community. - Pat Arnold [more]
Go Back   Chief Delphi > Technical > intelitek easyC/REC information > easyC PRO
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Authentic Touch Landscape
ADVERTISEMENT
Unread 01-12-2008, 05:16 PM
aeasson aeasson is offline
FRC #2435
aeasson is an unknown quantity at this point
EasyC Question regarding simple program
I am a mentor for Team 2435 in Lawton, OK.
We are using EasyC for our software development for the microcontroller.
Today we tried to compile and download the While Loop sample code provided by Intelitek. This is a simple program that loops ten times and uses PrintToScreen to write a mesage to the terminal window.
The compile and build was successful.
The download appeared to be successful.
The terminal window launched.
However, no messages came back to the terminal.
All of the lights on the board worked as expected and the green light indicates that the processor is running.
Is there any other action required to start to program on the board?
Is there any additional step within EasyC necessary to start receiving messages from the microcontroller board?
Thanks
Unread 01-12-2008, 05:28 PM
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Re: EasyC Question regarding simple program
Make sure you have the crystal plugged into the RC and the joystick, the joystick's antenna is extended, and the joystick is on. As far as I know, it won't run without the controller present.
What place are we at? ... TODAI!
Unread 01-12-2008, 05:50 PM
rhoads2234's Avatar
rhoads2234 rhoads2234 is offline
AKA: Erin
FRC #2234
Rookie Year: 2007
rhoads2234 will become famous soon enough
this is a good step
also try turning the robot off and then back on
or try redownloading the code
if none of these work download the online code and make sure you can control a motor or something
after you download online code you sure redownload your code
ALWAYS a mechanical problem!
Unread 01-12-2008, 06:00 PM
Samuel H. Samuel H. is offline
Rookie Year: 1000
Samuel H. has a spectacular aura aboutSamuel H. has a spectacular aura about
Check and make sure you have a connection between the Operator Interface and Robot Controller - the Radio Modem light on the robot controller should be green. You can try tethering the operator interface to make sure.
Unread 01-12-2008, 08:24 PM
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Make sure you have the GD Mode button deselected, or no printed text other than graphic display text will appear.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 01-13-2008, 08:32 AM
FRC #2435
Thanks for the responses.
I will try these suggestions tomorrow night at our next work session.
Unread 01-14-2008, 10:16 PM
FRC #2435
Again, thanks for the response.
We hooked the OI up to our controller and the programm started executing.
Thanks for your help.
Simple question on MPLabs itsme Programming 7 01-19-2007 11:05 PM
EasyC Program For Camera? G1279 Programming 1 01-08-2007 06:00 PM
HELP writing simple delphi program! dave_macca Programming 1 03-24-2004 11:35 PM
simple question... answer it archiver 2001 1 06-24-2002 12:02 AM
simple engineering question Ben Mitchell Technical Discussion 2 11-07-2001 06:50 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
