pic: 1458 Manipulator prototype1
Re: pic: 1458 Manipulator prototype1
cool... looks a little faulty though...
just think what would happen if someone hits you hard when you have the ball |
the angle is deceiving, there are two posts on top, one on bottom. we plan on adding plastic sides but of course we cant fully enclose (only 28" of bot, 40" of ball)
If the belt is pushing down hard enough it doesn't look like it will come loose, I like this design nice job on the prototype. What kind of reduction/rpm is the belt running at?
Cool! Looks like you guys are doing great this year!
We prototyped a design just like this on day 2 and it seemed to work well. However, I think you'll find that unless you are planning to build a very low drivetrain you may not be able to get the forks under the ball. A lower roller might be necessary... |
Thank you, we are further ahead of schedule this year then last, hopefully if you pick us again we will be more of a help . We have the bottom fork further behind then the top rollers, approximately 10". This allows the ball to come in contact with the rollers before the bottom forks. We haven't designed our drivetrain yet because This is our leading design, so if we select this design our base will be radically different. (probably a foot shorter then limit, and an open front)Last edited by Woody1458 : 01-12-2008 at 09:05 PM. |
wow that is so cool my idea was the same and this week i am working on a prototype and thats cool hows yours does it and also i was going to us two on top would that almost work better? with maybe one prong or maybe 2 prongs or just one solid ramp with grip.
also were would you get the CIM moters are they in the kit?
#10
Yes. Or you can get two in addition to the two in the kit. (total of four on the robot)
#11
We were considering this and i was just wondering what kind of distance and speed do you get out of that when you reverse the motors? Are you planning on hurdling?
#12
we are planning on hurdling with this, ill try to get a good test out of it tomorrow going reverse. this is just a prototype and ive been told the rollers the treads are on dont roll very good, so we wont get very accurate numbers.
#13
hey team 1485 are you guys going to give up one of your cim moters to power that hand? and what kinda tred do you to suck in the ball? is that a tank tred?
#14
we were planning on hurdling but now we are herding
#15
As Designer and builder of this prototype I will try to answer any questions you guys have.
I went OSH and they had this very flexible rubber stuff, I think used for weather stripping or something, was 1' 6" in width, cross section looked like this ^^^^^^^^^^^^^^^^^^^^^^^^^^ We decided on a CIM because Its small and fast, but people are still arguing over it so its not final. Last edited by Woody1458 : 01-15-2008 at 01:57 PM. |
| pic: 1458 teaser | Woody1458 | Extra Discussion | 15 | 01-11-2008 12:04 PM |
| pic: Team 418's Manipulator | Henry_Mareck | Extra Discussion | 3 | 04-04-2007 07:19 PM |
| pic: 1529 Lollipop Manipulator | Taylor | Robot Showcase | 7 | 02-26-2007 05:32 PM |
| pic: 121 Manipulator Prototype | Joe Menassa | Extra Discussion | 8 | 02-09-2007 05:13 AM |
| pic: 1458, 22 and 1097 | CJO | Extra Discussion | 1 | 03-31-2005 11:58 AM |
