Go to Post I am a mechanical engineer. I have known since I was about 12 that I wanted to make complicated mechanisms. - Paul Copioli [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 01-19-2008, 02:00 PM
Erich & Posse's Avatar
Erich & Posse Erich & Posse is offline
Will Forever!!!!!!!!!!!!!!!
AKA: Safety Dork
FRC #1504 (The Desperate Penguins)
Team Role: Leadership
Rookie Year: 2007
Erich & Posse is an unknown quantity at this point
How do you attach a pulley to extruded aluminum?
We need some help on our elevator design. We need to attach, preferably with a T-nut, a pulley (3/16ths shaft diameter) to a piece of extruded aluminum (30 mm track). Any ideas?
Unread 01-19-2008, 02:07 PM
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
Re: How do you attach a pulley to extruded aluminum?
basically thats the best and easiest way to do it. just use some washers to space the pulley so it doesnt rub on the aluminum
Unread 01-19-2008, 02:19 PM
AKA: Safety Dork
Rookie Year: 2007
You mean with a T-nut? That would be ideal, except we have a limited number of T-nuts... Is there an alternate way?
Unread 01-19-2008, 02:26 PM
EricH's Avatar
EricH EricH is offline
...has read the 2012 Manual
FRC #0330 (Beach'Bots)
Send a message via Skype™ to EricH
Go all the way through and use another type of nut, maybe.
Paths a rules question takes:
Official: Post to Q&A-->GDC reviews-->Official answer posted on Q&A.
Unofficial: Post to CD-->CD views and comments, sometimes using The Manual and interpreting it-->Somebody goes the Official route -->Answer gets posted on CD eventually, as a quote from Q&A.
Which one takes longer for an official ruling? Therefore, which one makes more sense to use?
Unread 01-19-2008, 02:29 PM
AKA: Safety Dork
Rookie Year: 2007
Sweeeeeet. Thanks
Unread 01-19-2008, 02:34 PM
Sam2197's Avatar
Team Role: Driver
t nuts are cheap. but you can just get a regular nut that fits back there and use that. if not. drill through all of it and use a bolt
[OCCRA]: extruded aluminum bernieseaholm OCCRA Q&A 1 09-19-2007 08:04 PM
80/20 Extruded Aluminum MTA Gearheads General Forum 8 01-20-2007 06:10 PM
T-Slot extruded aluminum blue_crew Technical Discussion 18 01-29-2006 12:05 PM
Mini extruded aluminum Ravi U Technical Discussion 7 01-17-2004 01:12 AM
How do you attach a wheel to a shaft? SilverStar Technical Discussion 21 01-21-2003 06:52 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
