Solidworks Weights
Is there a way I can tell solidworks that a part weighs a certain amount without having to put in a density? For fast CAD'ing, I know how much components weigh because I can weight them; but finding their volume is another matter and it's faster to simply weigh each piece and put it in a spreadsheet and create a simple representation of the part without all the nooks and crannies.
However, since I want to be able to simply go to our final robot drawing and then "mass properties" to get the weight, a spreadsheet will not suffice. I'd also like to put the weight on the bill of materials. Any ideas? |
Re: Solidworks Weights
Yes in SolidWorks you can assign a custom mass/weight to a part or assembly and then link that information to the drawing through Custom Properties. You are going about setting a custom mass the correct way but now you need some additional steps.
For a part of assembly, select tools, mass properties. Enter the value for the mass. In the ConfigurationManager, right-click Default. Click Custom Properties. Select Weight for Property Name. Select from the drop downlist "Mass" for Value. You need to use the SW-Mass Now create your drawing, use the predefined BOM template that contains Mass. You mass from the model will be displayed. There is a movie of the solution at http://blogs.solidworks.com/teacher/...f-materia.html Good luck. Marie |
| Motor weights | KoulFireChick | Motors | 0 | 01-16-2008 06:45 PM |
| Track Ball weights | EStokely | General Forum | 7 | 01-08-2008 08:45 PM |
| Cylinder weights | Captain Rich | Pneumatics | 3 | 03-30-2005 03:08 PM |
| Part Weights | bwood720 | Kit & Additional Hardware | 0 | 01-21-2003 04:14 PM |
| Component weights | GregT | General Forum | 4 | 01-11-2003 01:29 PM |
