Go to Post Teaching students should take place in the offseason. Applying the skills learned is what the real season is for. - [more]
Unread 01-30-2008, 03:12 PM
JCODER's Avatar
JCODER JCODER is offline
-1672 Programming Team
FRC #1672 (Mahwah Robo T-Birds)
Team Role: Webmaster
JCODER is an unknown quantity at this point
Exclamation How to wire solenoid valves????????
Yeah, I'm new to the whole pneumatics thing, does anyone know how to wire the solenoid valves for the pneumatic system? Like do you need a spike in order to hook up the solenoid???
Unread 01-31-2008, 01:35 PM
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: How to wire solenoid valves????????
Yes, you need a spike controlled via an RC Relay port.
The solenoid connects to the Spike M+/M- terminals.
A single-action solenoid connects the red wire to M+ and the black wire to M-.
A double-action solenoid (two sets of wires) connects one red to M+, the other red to M-, and both black ground wires to the ground on a fuse block or other appropriate ground connection.
“It is not surprising that our common sense fails to grasp the true universe. The problem lies in assuming that our common sense represents reality.” – Michio Kaku
Unread 01-31-2008, 02:45 PM
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
the easiest solution I have used is just to connect the black wires to the V- input on the same spike.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 01-31-2008, 07:11 PM
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
Check this out: Blue Spike / Solenoid Wiring Guide
where are double solenoid valves placed Reaper40 Pneumatics 5 01-28-2007 02:54 PM
solenoid valves? brian1717 Pneumatics 2 01-07-2007 02:28 PM
Q&A Discuss: Cylinders + Solenoid valves CD47-Bot Extra Discussion 1 02-05-2003 04:21 PM
Cylinders + Solenoid valves Greg General Forum 2 01-28-2003 08:29 AM
Does anyone have extra solenoid valves????? Elgin Clock Pneumatics 5 02-18-2002 11:43 AM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
