Go to Post so this is going to sound really dumb but remember that i am a mechanical guy. - Greg Needel [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Chief Delphi Alumni
ADVERTISEMENT
Unread 01-30-2008, 03:19 PM
Mrtrom Mrtrom is offline
AKA: Aaron Baker
FRC #0085 (BOB)
Team Role: Animator
Mrtrom is an unknown quantity at this point
Ball Bearings
I am new this year on FIRST, and i was wondering if ball bearings will begin to "lock up" after long periods of use
Unread 01-30-2008, 03:39 PM
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: Ball Bearings
That is one of the nice things about FIRST. Unless you are able to get considerable drive time before the ship date, you do not usually have to worry about Ball Bearings. Think of it this way, 24 hours of running your robot equals about 640 matches, with very little continuous use. We have never had problems with ball bearings on our robot. I guess it depends on what you consider long periods of use.
EDIT: Making certain that they are lined up to begin with also helps.
Unread 01-30-2008, 03:56 PM
EricH's Avatar
EricH EricH is online now
...has read the 2012 Manual
FRC #0330 (Beach'Bots)
Send a message via Skype™ to EricH
Re: Ball Bearings
I've never ever seen a ball bearing lock up in FIRST. 330's practice robot last year went through the mill--the drivers barely waited for the batteries to charge before driving again; it won a preseason, and is still running today. No bearing failure.
Paths a rules question takes:
Official: Post to Q&A-->GDC reviews-->Official answer posted on Q&A.
Unofficial: Post to CD-->CD views and comments, sometimes using The Manual and interpreting it-->Somebody goes the Official route -->Answer gets posted on CD eventually, as a quote from Q&A.
Which one takes longer for an official ruling? Therefore, which one makes more sense to use?
Unread 01-30-2008, 05:26 PM
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #1729 (Plan B)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: Ball Bearings
Ball bearings usually are overkill for a FIRST application and should last far beyond the life expectancy of your robot.
A couple of things to note: Ball bearings like even loads meaning that the shaft that goes through the bearing pack (I'm assuming you are using a bearing pack and not just ball bearings in a channel) is in line with the hole and not canted. The other thing is that ball bearing packs tend to not like side loads.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
WHere do you get Ball Casters/ BAll Transfers for FRC?!?!?!? leehyungjin4u General Forum 3 01-15-2008 10:27 PM
Purchasing Ball Bearings FIRST JerseyKid Kit & Additional Hardware 7 04-30-2007 08:11 AM
Where to buy Ball Bearings? ThatIndianKid89 Kit & Additional Hardware 3 01-20-2007 02:59 PM
Threaded rod through ball bearings Madison Technical Discussion 38 01-03-2007 12:23 AM
Drills: The ball bearings are gone? BobbyG Motors 0 01-21-2003 10:57 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
