Go to Post Nerd harder, be seen doing it... don't care what others think. - Mr. Lim [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Delphi
ADVERTISEMENT
Unread 02-06-2008, 04:25 PM
babylyn90 babylyn90 is offline
A Proud Noob
AKA: Desiree
FRC #2265 (Iron Maidens)
Team Role: Electrical
babylyn90 is an unknown quantity at this point
Send a message via AIM to babylyn90 Send a message via MSN to babylyn90
backup battery charger circuit help
Hey guys, Desiree here from 2265. We're trying to build our own backup battery charger based off the circuit we found posted on another thread. A few questions came to mind since we can't seem to find some components:
1.) I was wondering if we'd be able to do series connections with some of the resistors in a way that would add up to the needed voltage. In example, combine 1K, 200ohm, and 40 ohms resistors to make the 1.24K in R3.
2.) Are precise values necessary? In example, could I use 220 ohms instead of 221 ohms for R2?
3.) I can't seem to find the zener diodes either
4.) Does it matter what I build the circuit on? Recommendations?
I'd really appreciate it if you guys could post either with links or tips to other threads/posts i might have missed. Thanks and sorry if this was already posted, i probably missed it!
Unread 02-06-2008, 04:31 PM
GrammarNazi GrammarNazi is offline
FRC #2952
GrammarNazi is on a distinguished road
Send a message via AIM to GrammarNazi
Re: backup battery charger circuit help
1) yes, i forgot that you could
2) no, try to get it as close as possible though
3) try mouser electronoics of even radioshack they shouldnt be hard to find
4) i would just build in on a prefab general purpose circuit board, making your own would take to much time and energy
First one to reply gets a cookie!!!
Unread 02-06-2008, 04:32 PM
FRC #2952
also you can just buy a charger for like 20 buck thats guarenteed to work and take it apart and use that that might be easier
Unread 02-06-2008, 04:43 PM
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to behold
Send a message via Yahoo to kevin.li.rit
1) You can connect them in series, it'll have the same effect. (You might want to measure it with a ohm meter to see how close you are to 1.24k)
2) The schematic doesn't mention anything about the percision so I doubt 1 ohm will kill you.
3)It's a digikey part number for the Zener 1N5345BMSCT-ND. It gives you a substitute. You can also try mouser like grammar said.
http://search.digikey.com/scripts/Dk...1N5345BMSCT-ND
This one should be good too.
http://parts.digikey.com/1/parts/421...8-1n5345b.html
4) I would probably build it to a solder on break board.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 02-06-2008, 05:11 PM
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #0364 (Team Fusion)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Send a message via Skype™ to RyanN
For the resistors, I used a potentiometer and set it to 7.5 volts and skipped the Zener Diode and the battery will just slowly charge using the resistors that go around the diode connected to the battery. I did not include the resistor from the 12V to the backup battery as I saw no real reason to include it. What I have right now supplies a steady 7.5V and I think it will work reliably. I also added a diode so it would not try to power the whole robot once the breaker was switched off.
Controls Mentor
firstfusion364.com
Backup Battery Charger byrnedfish General Forum 3 01-31-2008 08:23 PM
backup battery charger falconmaster Electrical 16 01-22-2008 11:04 AM
Where to connect the backup battery charger Never_Fade Electrical 6 01-16-2008 10:54 PM
Need help with build a custom circuit for the backup battery midway78224 Electrical 7 01-09-2008 07:17 PM
Alternate Backup Battery Charger Phalanx Electrical 5 02-24-2007 01:51 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
