Go to Post Instead of dreading the potential alliance think of ways to impress them so they want you to be part of it! - Koko Ed [more]
Unread 02-09-2008, 10:34 AM
CyDrive's Avatar
CyDrive CyDrive is offline
FRC #1203 (pandemonium)
Rookie Year: 2007
CyDrive is an unknown quantity at this point
Help with mecanum wheels
We recently purchased the mecanum wheels and have tried different ideas to get all the motors to spin at exactly the same speed at time. We have tried a bias but that didn't work due to the increase or descrease in our margin of error over time. I have searched the forums and have yet to find anything we could really use. If anyone could help it would be appreciated.
Unread 02-09-2008, 11:51 AM
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: Help with mecanum wheels
You could use geartooth sensors to monitor the changes and adjust the speed accordingly. I know we have used this for autonomous in the past.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 02-09-2008, 12:03 PM
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
Rookie Year: 2007
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
I'd recommend a PID for velocity. You'd set up one for each wheel, and then just change the target values every time you needed too, I suppose. Or maybe just for autonomous, as trying to brake wouldn't work...
Anyway, there are a couple of whitepapers on PID you can use, and I know Kevin Watson has PID for velocity already made and ready to go. They work very well if you can use them.
Unread 02-09-2008, 03:05 PM
3dude_2231's Avatar
3dude_2231 3dude_2231 is offline
no one messes with a Thingy =|
AKA: Menscher,Ran Menscher =]
FRC #2231 (Onyxtronix)
Team Role: Leadership
Rookie Year: 2007
3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough
Send a message via MSN to 3dude_2231
we had the same prob, too.
here's what you should do:
* if your using motors from different years, place them in a logical order,
for example: 2 08s in the front, and 2 07s in the back.
* grease the gears evenly, and don't be cheap =]
* calibrate the Victors
* use wide and even cables between Victors and fuses, just in case
* make sure, and you better be real sure your joystick is calibrated and trimmed
and your code is correct.
Redefining the word "Rookie". (for 2 years now..)
Israeli Off Season Games: WINNERS!
check out this cool project I'm into..
Unread 02-09-2008, 03:36 PM
manderson5192 manderson5192 is offline
AKA: Matt Anderson
FRC #0948 (Newport Robotics Group: NRG (pronounced eNeRGy))
Rookie Year: 2007
manderson5192 is on a distinguished road
My team had the same issue as well. We used one encoder to get RPM data for every PWM value and produced a graph of this data. Using this graph we were able to see which victor/cim pairs were consistently faster and where the respective "true" dead zone of pwm values were for each victor. We immediately saw the dead zone ended up centered at 133, not 127. By shifting all PWMs up by six and limiting PWMs so they wouldn't overflow the max of 254 we were able to get a nearly perfect strafe.
Something you might also consider is using encoders, gear tooth sensors, or the gyro in a PID loop.
Unread 02-10-2008, 01:30 PM
team1203 4life's Avatar
team1203 4life team1203 4life is offline
President
FRC #1203 (Pandemonium)
team1203 4life is a jewel in the roughteam1203 4life is a jewel in the roughteam1203 4life is a jewel in the rough
Send a message via AIM to team1203 4life
yo mike what would happen if we where to wire the fl trany and the br trany to the same speed control and wire the fr trany and bl trany to the same speed controler and place a gear tooth sensors in the fl and fr tranys so they could all be regulated and fire at the same time so it would not vear off course
if it is on one of my posts it is propbly spelt wrong
Why drive around somthing when you can drive through it
Unread 02-10-2008, 03:09 PM
CyDrive's Avatar
Rookie Year: 2007
That would work as long as you can hook up two motors to a vicktor.
Unread 02-10-2008, 03:16 PM
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
One of your issues you may be experiencing is the manufacturing differences in DC motors. No two motors will ever spin at exactly the same speed and unequal weight at friction will cause you to drift of course. Btw you can not wire 2 motors to the same speed controller. I would suggest to make your system as efficient as possible and then if that doesn't work either program PID or some other closed loop or get your drive to compensate for the drift. Out robot drifts to the right this year so every time i drive I always give the right joystick more of a push than the left.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Bumpy Ride with AM's 8" Mecanum wheels? Leav Technical Discussion 12 02-14-2008 12:16 AM
need help about Mecanum Wheels mahmosh Technical Discussion 4 01-18-2008 10:50 AM
Assistance with Mecanum Wheels CollmandosGrl General Forum 8 01-14-2008 04:42 PM
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 12-16-2006 06:40 PM
Teams With Mecanum Wheels Foss@Team176 Technical Discussion 15 10-06-2005 08:38 AM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
