2 batteries
does any one know if there are any rules about not haveing two of the 12 volt batteries on your robot. one that powers the robot and another for weight in the front of the robot.
i will upload a picture later today so that you can see what i am talking about. |
Re: 2 batteries
Yes, there is a rule that specifically says you can only have one 12v battery on your robot.
"<R45> Items specifically PROHIBITED from use on the ROBOT include: ...... More than one primary battery, or more than one back-up battery" . If you need ballast, find something else! A battery is a dangerous thing. |
Re: 2 batteries
thanks for the information.
Re: 2 batteries
no its not allowed... just get a ton of steel that you can use as ballast and put it up there (=
Re: 2 batteries
In a game of speed, weight is never a good thing.
Is there a way that you wouldn't have to use ballast, or place the battery up front where the ballast would go. You don't want weight on fast robots, (but maybe you do) any hints on what your robot is, or what it looks like. |
Re: 2 batteries
Ballast is still governed by other rules. Be sure it meets the flowchart for allowables and that it is securely mounted on your robot. Tywraps do not count!
Re: 2 batteries
You can buy 5 and 10 lb iron weights at discount department stores, and the have a convenient hole thru the center for mounting.
Re: 2 batteries
get some lead i litterly have a ton of it in my back yard it works great as a counter weight.
Re: 2 batteries
)-dave . |
#10
Re: 2 batteries
![]() On a philosophical note, does a battery count as a battery if it's not part of the electrical system? Yes, yes, I know the rules about one and only one 12v primary battery, but if it's not plugged into anything is it really a battery? Is it not just a battery shaped weight? Not that I'm advocating for using extra batteries as weights, but still an interesting point of discussion. Last edited by TubaMorg : 02-13-2008 at 12:11 PM. Reason: Needed a cheesy grin |
#11
Re: 2 batteries
Seriously, I would argue that a battery is a battery at any time. If it is only a battery when current is flowing, then anytime the main breaker is hit, the battery becomes a battery-shaped weight. If it is only a battery when hooked into the electrical system, then you're charging a battery-shaped weight. (Don't get any ideas.) More importantly, a battery has the potential to suddenly become a spark generator at any time. As soon as it hits metal on both contacts, it becomes a safety hazard, but it may or may not be plugged into an electrical system. Is it not a battery then? |
#12
Re: 2 batteries
Gentlemen,
Although lead seems to be an ideal ballast material, remember that in some areas lead is considered a hazardous material. It may not be cut or machined at events and should be painted or coated to prevent students (and mentors) from ingesting contaminants while eating with their hands. |
#13
Re: 2 batteries
Last year we filled two acculator tanks with lead shot worked great because we were not using air and you can fit about 5lbs into one, (i think) and it is sealed with two plugs.
#14
Re: 2 batteries
Re: 2 batteries
...the old motors would have to be currently available COTS
| Batteries | Mike Martus | General Forum | 26 | 02-19-2007 11:47 AM |
| MK Batteries | Mike Martus | Electrical | 0 | 01-11-2007 09:09 AM |
| Batteries | Der Sichelmann | Electrical | 18 | 02-22-2005 09:17 PM |
| Batteries | MechaJagEric | Electrical | 9 | 02-21-2003 11:48 AM |
| Batteries | MechaJagEric | General Forum | 2 | 01-27-2003 08:18 PM |
