Go to Post Let's see. There's the Dean of Students, the Dean of Admissions, The Dean of Engineering, and the Dean of Kamen? Sometimes known as the Denim Dean. - Bill_B [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ProCare Services
ADVERTISEMENT
Unread 02-13-2008, 05:36 PM
govvijay govvijay is offline
FRC #0540
govvijay is an unknown quantity at this point
Printing Analog Input with Kevin's new code
We are trying to print analog values from our autonomous switch, but we are only getting 0 values. I was just wondering how do you print analog inputs using Kevin's new code.
Thanks,
Vijay G.
Unread 02-13-2008, 05:45 PM
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
Rookie Year: 2007
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: Printing Analog Input with Kevin's new code
It should be normal, something like:
Code:
        for (k = 1; k <= NUM_ADC_CHANNELS; k++) {
            printf("ADC %d: %d\r\n", k, Get_ADC_Result(k));
If you want to get fancy. Make sure the number of ADC channels is set correctly in adc.h. This looks more like an electrical problem though. You may want to check with an oscilloscope that you are actually getting values from the ADC.
Unread 02-13-2008, 08:21 PM
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Code:
Get_ADC_Result() returns an unsigned int, so you'll want to use %u in your printf() format string instead of %d.
-Kevin
Kevin Watson
Engineer at Space Exploration Technologies (SpaceX)
http://kevin.org
Problem with Kevin's 2008 code jc4p Programming 4 02-06-2008 04:48 PM
Errors compiling Kevin's new code (pragmas) Tanis Programming 11 01-31-2008 11:50 AM
Problem with Kevin's code Tottanka Programming 5 11-04-2007 12:32 PM
Problems with Kevin's 2007 default code bruss6 Programming 8 01-19-2007 02:42 PM
What are with the Ls in Kevin's code??!!! HELP!!! RbtGal1351 Programming 2 02-18-2005 03:57 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
