KOP Gyro Lag
My team is experiencing a problem with the gyro included in the KOP this year. It appears to have a lag of almost a second after any large turn. For example, if we make a 90 degree turn and print out the gyro value each 26ms loop, the gyro will think it's still turning for 30-40 loops after the turn has stopped and motors have been set to neutral. The gyro value will be around 75 (on a 0-255 scale) and gradually return to neutral, but it will not reach neutral until almost a second after the robot has stopped turning.
This is a big problem because we intend to use the gyro to allow the robot to maintain a straight heading during autonomous mode. Basically, we store a neutral rate before we start moving, then slow down either the left or right motors when the gyro value deviates from that rate to counteract any deviation from a 0 heading. This works perfectly if we just tell the robot to go straight. But if we tell it to turn left and then go straight, it will make a large turn to the right. This is because, for about one second after the left turn, the gyro will still say we are turning left. The robot will then attempt to "correct" for this by slowing down the right motor, but since the robot isn't really turning left, it will actually turn right. We are using IFI's default code right now, but we tried converting everything over to Kevin's latest code to see if that would help. Unfortunately, it didn't. For about one second after a fast turn, Kevin's gyro code reports a turn rate of over 1,000 tenths of degrees per second. Yes, I know, that's way over the 800 tenths of degrees per second limit of the gyro. We're thinking our problem is that we are saturating the 80 dps gyro, and that is making it do weird things. So, our plan is to go buy the ADXRS300 and be done with it. We aren't 100% sure saturation is our problem, however, and we don't want to spend $70 just to find out that it still doesn't work. So, here's our question: can anyone here who has the ADXRS300 confirm that it does not have the lag problems described above? (or recommend another gyro that doesn't have the problems described above) Thanks, Josh - Team 339 programmer Last edited by FRC4ME : 02-14-2008 at 12:40 PM. |
Re: KOP Gyro Lag
2 things:
1. I believe the lag you are seeing is related to your print out rather than true lag. Output to screen takes more time than the slow loop, so what you are seeing as output happened a while ago. When you are outputing a dynamic value every loop, the buffer backs up. You could try adding a counter and just print every 10 loops or so. 2. The 80 deg/sec gyro is ok if you just want to use it to help drive straight, but it is hard to turn the robot that slow. I would definitely go with the 300 deg/sec gyro. Again lag issues you are observing aren't originating from from the gyros themselves so that isn't an issue. |
Re: KOP Gyro Lag
I also doubt the printout is my problem because I am using another printout as a reference. Every single slow loop, I print out a counter called "time tic" so I know how many slow loops have passed by. When the robot turns, it does so using gear tooth sensors, and prints out a message when the turn is finished and motors have been set to 230 each again (for another straight run). After that message, the gyro value printout (which also prints every loop) indicates the robot is turning for the next 30-40 time tic printouts. Yes, it is true that all of these printouts are delayed. But the "turn finished" prinout would also experience the same delay. Regardless, there are still 30-40 loops between the end of a turn and when the gyro stops reporting a turn. |
Re: KOP Gyro Lag
yeah this years KOP can only measure 80 deg per second(as opposed to last years 150). . . read your sensor manual . . . . yeah kinda sucks.
Re: KOP Gyro Lag
Just for fun try slowing down your printf's and see if that has any affect. If not then you have another chunk of code that is lagging. The gyros don't lag. Are you using any for loops? Any other loops?
Re: KOP Gyro Lag
3Here's an example of what my terminal windows looks like after I get after telling the robot to turn, then go straight. This isn't actually code - it's what prints out into the terminal window. First, it does the turn, and the gyro value reflects that:
Code:
Autonomous State = Turn Loop Number = 1 Gyro Value = 75 Left Motor = 127, Right Motor = 230 Autonomous State = Turn Loop Number = 2 Gyro Value = 75 Left Motor = 127, Right Motor = 230 Autonomous State = Turn Loop Number = 3 Gyro Value = 75 Left Motor = 127, Right Motor = 230 Autonomous State = Turn Loop Number = 4 Gyro Value = 75 Left Motor = 127, Right Motor = 230 Code:
Autonomous State = Turn Loop Number = 32 Gyro Value = 75 Left Motor = 127, Right Motor = 230 Autonomous State = Turn Loop Number = 33 Gyro Value = 75 Left Motor = 127, Right Motor = 230 Autonomous State = Turn Loop Number = 34 Gyro Value = 75 Left Motor = 127, Right Motor = 230 TURN DONE Code:
Autonomous State = Straight Loop Number = 35 Gyro Value = 75 Left Motor = 230, Right Motor = 230 Autonomous State = Straight Loop Number = 36 Gyro Value = 75 Left Motor = 230, Right Motor = 190 Autonomous State = Straight Loop Number = 37 Gyro Value = 75 Left Motor = 230, Right Motor = 160 Autonomous State = Straight Loop Number = 38 Gyro Value = 75 Left Motor = 230, Right Motor = 140 Autonomous State = Straight Loop Number = 39 Gyro Value = 75 Left Motor = 230, Right Motor = 127 Autonomous State = Straight Loop Number = 40 Gyro Value = 75 Left Motor = 230, Right Motor = 127 Autonomous State = Straight Loop Number = 41 Gyro Value = 75 Left Motor = 230, Right Motor = 127 Code:
Autonomous State = Straight Loop Number = 75 Gyro Value = 80 Left Motor = 230, Right Motor = 127 Autonomous State = Straight Loop Number = 76 Gyro Value = 95 Left Motor = 230, Right Motor = 150 Autonomous State = Straight Loop Number = 77 Gyro Value = 115 Left Motor = 230, Right Motor = 180 Autonomous State = Straight Loop Number = 78 Gyro Value = 127 Left Motor = 230, Right Motor = 230 Note that I was putting that into my own words since I didn't save the terminal printouts and can't get new ones right now. The gyro value actually varied between 72 and 78 during the turn. I can slow down the printouts, but I don't see how that would help. Yes, all of the printouts are delayed. In fact, we get a red light of death if we run autonomous mode for too long with those printouts on (serial buffer overflows). But all of the prinouts should be affected by the same delay. The fact remains that, for forty tics after the turn stops, the gyro reports that we are still turning. The only way the printouts could be the problem is if they were somehow slowing down the ADC but not the rest of the code. I'll try slowing down the printouts to once every ten loops tomorrow (we're taking today off), but I doubt it will help. I think the problem is related to us exceeding the gyro's 80 dps range during the turn, but like I said, we don't want to buy the 300 dps version only to find out that it has the same lag. What exactly happens when you exceed the gyro's range? Will it simply report its maximum range and then go back down when you stop turning? Or will it get "stuck" at its maximum range for about a second? And no, we aren't using any other loops in our code except the master 26.2ms loop. We used to use a while loop to do atuonomous, but we fixed that. There are a few floating point operations, but nothing too complicated. Last edited by FRC4ME : 02-14-2008 at 12:40 PM. |
Re: KOP Gyro Lag
However, that doesn't mean code on the RC couldn't introduce a lag in the readings, but I too, doubt it. None of our gyro's have ever exhibited a lag. We use 300 deg/sec gyro's on the robot, but other gyro's in demonstrations. The gyro values in your sample printout seem very odd. Where exactly are you getting your gyro values from and what do they represent? |
Re: KOP Gyro Lag
Code:
unsigned char ucGyroValue = (Get_Analog_Value(rc_ana_in01)) >> 2 The thing is, only a turn triggers the lag. Like I said, if we tell the robot to go straight, it does just fine. If we print out the gyro value in main.c every loop, it prints a constant neutral or something very close to neutral when the robot is stationary. If we manually nudge the robot, the printed gyro value changes instantly with almost no lag at all. But if we make a sharp turn during autonomous, the value lags considerably. In case it matters, we are calling a separate function to calculate motor corrections. It gets the gyro value, calculates a motor correction percentage, and return the correction percentage to the caller. Here's the entire function if it matters. There is one fabs but from what I've read that shouldn't be a problem if we only use it once. Code:
static float fCorrectMotorsForOutOfAlignmentGyro (
eDecreaseWhichMotorEnum *peDecreaseWhichMotor) // tells the calling function which
// which motor needs the adjustment on
unsigned int uiGyroValue = GET_ANALOG_VALUE(GYRO_INPUT);
// The analog value from the gyro at present
float fPercentageOfChangeToMotors = 1.0; // The number that will be multiplied by the current motor speed to slow
// it down for a correction (i.e. 0.99 will slow down the motor by 1%)
// Positive values indicate we are too far right. Negative values indicate we
// are too far left
// if the caller didn't pass in the correct
// argument type, simply return a NO_CHANGE
// value. Preset the change goes to the
// LEFT motor
*peDecreaseWhichMotor = DECREASE_LEFT_MOTOR;
if (peDecreaseWhichMotor == NULL)
return (fPercentageOfChangeToMotors);
// Depending on the direction we are turning, increase or decrease our total
iGyroTotalError = iGyroTotalError + (uiGyroValue - iGetGyroStartingValue());
// Calculate the percentage of change based on how far off we are (gyro error) and our constant
// motor correction curve valuee (FACTOR and CURVE)
fPercentageOfChangeToMotors = 1.0 -
MIN((MOTOR_CORRECTION_FACTOR * fabs(iGyroTotalError / MOTOR_CORRECTION_CURVE)), 1.0);
// if we are drifting to the left
// then we need to let the called
// functions know by denoting that we
// want the RIGHT motor to be decreased
if(iGyroTotalError < 0)
*peDecreaseWhichMotor = DECREASE_RIGHT_MOTOR;
# define DEBUG
# ifdef DEBUG
printf("The gyro value is %d." EOL, (int)uiGyroValue);
printf("The gyro error is %d." EOL, (int)iGyroTotalError);
printf("The percentage of change %d.%d" EOL, (int)fPercentageOfChangeToMotors, (int)FLOAT_FRAC_PART(fPercentageOfChangeToMotors));
# endif // DEBUG
# undef DEBUG
} // end fCorrectMotorsForOutOfAlignmentGyro
You'll notice the function has an accumulator, iGyroTotalError, which keeps track of how far off of a zero heading we are. The robot will actually try to turn back to a zero heading based on this value. iGetGyroStartingValue() gets the gyro neutral value, which we measure right before we start autonomous mode. MOTOR_CORRECTION_FACTOR and MOTOR_CORRECTION_CURVE are defines that control how large the corrections to the motors are. EOL is a define we made that inserts whatever this years "go to the next line of the terminal screen" command happens to be. Sometimes it's \r, sometimes it's \n, sometimes it's \r\n...so we just made a macro to avoid having to change every single printf statement if the command changes again. Last edited by FRC4ME : 02-14-2008 at 03:07 PM. |
Re: KOP Gyro Lag
-Kevin |
#10
Re: KOP Gyro Lag
Just did some searching and it look like I'm not crazy after all.
Check out this thread: http://www.chiefdelphi.com/forums/sh...ad.php?t=55200 Quote:
And here's one of the responses: Quote:
Any thoughts? |
#11
Re: KOP Gyro Lag
The topic that I linked to above tells me it isn't an ADC problem, since the person who posted that topic tested the same analog input with a POT and there was no lag at all. |
#12
Re: KOP Gyro Lag
-Kevin |
#13
Re: KOP Gyro Lag
Re: KOP Gyro Lag
I just tried a really short cable and it didn't help. We still have the same 1 second lag. I think we're just going to order a new ADXRS300 having eliminated all other potential sources of the problem.
| Lag Issue | bizarospooky | Programming | 7 | 02-08-2008 04:31 PM |
| Some 2007 KOP Gyro Performance Data | yoyodyne | IFI Control System | 3 | 04-02-2007 07:07 PM |
| KOP Gyro seems to run-on after turn stops | PhilBot | IFI Control System | 8 | 03-05-2007 11:43 AM |
| KOP Gyro | John Gutmann | Programming | 12 | 12-12-2005 08:59 PM |
| Lead-Lag Compensator | eSouL | IFI Control System | 0 | 08-13-2004 02:21 AM |
