motor jolts
We're using a function in our robot's code that lessens the sensitivity of the analog sticks. But now when we run it, as we slowly press forward on the sticks, they go forward but then they stop and go backward very quickly and then goes forward again. It's like it "jolts" as its going forward. We tested the code throughly and we figured out it's not the math of the code. So we have no idea what is going on. Anyone have any suggestions?
Re: motor jolts
Dude,
Is it possible you are trying to overcome a problem with the joysticks by writing code? I always have to ask...Are your speed controllers calibrated? This simple function will match the extremes on your joysticks to max output on the speed controller. It is very easy to watch the LEDs on the controllers to see where (or if ) they achieve full red or full green as you move the joystick forward and back. If they do not, then calibration is the easy answer. Joysticks also exhibit electrical noise as they move and this may be interpreted by your code as a human commanded direction change. |
Re: motor jolts
Yes we calibrated the controller. We're using the xbox 360 controller with the USB chicklet so we calibrated both the analog sticks. I don't know if that changes the calibration problem or not, but there's not any LED's that indicate whether or not we're at the maximum or minimum for the joysticks.
Re: motor jolts
We were having the same problem. When you push the joystick to turn left, the robot jerks right then goes left. The thing that confuses me is that this doesnt happen when you turn right. We did calibrate the victors, but it was a few weeks ago, it may be something to look at.
Joey |
| 2 motor adapter and keyang motor dimensions | Bruno Estevão | General Forum | 1 | 02-16-2007 08:36 AM |
| White Paper Discuss: Approx. Motor Spec for Taigene Motor | Joe Johnson | Motors | 2 | 01-22-2005 03:36 PM |
| Is it okay to run one motor in a two motor transmission? | NoodleKnight | Technical Discussion | 27 | 12-16-2004 06:16 AM |
| External metal jacket on the Drill motor and FP motor, WHY? | archiver | 2001 | 3 | 06-24-2002 03:22 AM |
| External metal jacket on the Drill motor and FP motor, WHY? | Dennis Hughes | Technical Discussion | 1 | 06-04-2001 10:59 AM |
