IFI Dashboard Sorce Code
Does anyone know if IFI offers source code for the Dashboard program? I am planning on making a Custom GUI (really it is a GI) for our ROV and I thought the source code will save me a lot of time. Although i have been told it is possible I have never seen it done. I greatly appreciate any help someone can give, Thank you.
I will try to do this in VISUAL BASIC Last edited by kE7JLM : 02-19-2008 at 11:46 PM. |
Re: IFI Dashboard Sorce Code
The source code for the IFI Dashboard is not available. They did document the protocol, so you can write your own. There are also several versions in the whitepaper section here, for which the source is available.
Or you can use this:
http://www.chiefdelphi.com/media/papers/1765 You just write a user control that inherits from a base class and implement the callbacks that receive dashboard packets. You can write it in either VB.NET or C#, whichever you prefer. You don't have to parse anything or worry about the serial IO. There are a few nice controls in the 2008 control library. It also has a UDP packet relay that lets you share the data stream with another PC running the dashboard software. |
Thanks for this. I'm trying to create a much more intuitive dashboard for our robot. I'm going to try an recreate this using WPF. Will hopefully update soon!
| Problems integrating CMUCAM code and IFI Default Code | Windward | Programming | 2 | 02-06-2007 03:48 PM |
| 2007 IFI default code question | Japper | Programming | 4 | 01-22-2007 10:23 PM |
| IFI Analog Code | David Carter | Programming | 6 | 09-12-2006 02:35 PM |
| Labview Dashboard and updated IFI dashboard spec | Joe Ross | LabView and Data Acquisition | 1 | 04-04-2006 01:04 AM |
| Code for the Dashboard | HuskieRobotics | Programming | 1 | 03-04-2004 10:10 AM |
