Go to Post All robots can be defeated with strategy. - Alexander McGee [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 02-23-2008, 07:09 PM
GVDrummer's Avatar
GVDrummer GVDrummer is offline
AKA: Jake Hall
FRC #0216 (RoboDawgs OTL)
GVDrummer is on a distinguished road
Send a message via AIM to GVDrummer
What does your robot do?
So after the end of the season, what does your robot do and how does it do it?
Ours has a giant claw that grabs the ball and releases it over the overpass, also is can hold on to the ball until we need to let it go.
Unread 02-23-2008, 09:47 PM
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: What does your robot do?
We have a lifter that can push the ball off of the overpass. Once it's down, we can herd it around the track very quickly with a 36" diameter hoop. The hoop comes down on top of the ball, and the best description I've heard is that it looks like a halo of sorts.
Unread 02-23-2008, 09:56 PM
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Our has a massively overpowered double jointed arm. Why massively overpowered you ask? Well, in addition to its normal herding, placing, slow hurdle, and removing capabilities, our arm is a catapult. The catapult function was never tested due to chain slippage and a software bug (both easily fixable), but with over a horsepower driving the shoulder joint (none of this stored energy nonsense, we just use raw power), that ball is going somewhere fast. The robot also can run a 12sec lap with six robots and four balls on the field, and it will only get faster as I get more practice driving it.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 02-23-2008, 10:12 PM
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
we have a poker that pokes the ball off, and we have a claw that grabs and releases the ball . . we may have a catapult if we can get it working(with out any one having to tap it every time to set it off ) on Thursday.
we can also drive around poking our colored balls and drive around really fast while not hitting any thing . . . with out any input from the drivers
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 02-23-2008, 10:27 PM
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
we have a bendy claw that is able to create an iron grip on the ball, and a double jointed arm to lift it. The arm is springy, so our drivers are able to use it to do an overhead throw.
our arm also doubles as a ball knocker in high speed.
more here
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 02-24-2008, 12:47 AM
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
401 can Capture the ball off the over pass, herd, hurdle, and place!
Video HERE!
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 02-24-2008, 02:50 AM
BQuennell's Avatar
BQuennell BQuennell is offline
Electronics Mentor
FRC #1388 (Eagle Robotics)
BQuennell has a spectacular aura aboutBQuennell has a spectacular aura about
Send a message via AIM to BQuennell Send a message via MSN to BQuennell Send a message via Skype™ to BQuennell
We use claws attached to a globe motor to lift up the ball and a large "hammer" to kick the ball over the overpass.
Eagle Robotics Team 1388
It's Hammertime!
2005 SAC Engineering Inspiration Award
2006 SAC J&J Sportsmanship Award
2007 LA Xerox Creativity Award
2008 SD Xerox Creativity Award
2008 SAC Regional Finalist
2008 SAC Engineering Inspiration
Unread 02-24-2008, 06:33 AM
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
When a judge asks you this question, he or she really means "How does your robot do what it does?" Every team member should be able to answer that question in detail, or at least be able to refer the judge to someone who can answer it: "Well, I didn't work on the pneumatics myself, but Andy over here can tell you ..."
A couple years ago I was judging in OCCRA, a fall competition in Oakland County. I asked one team member to tell me about her robot. "Well, it drives and, um, " And that was about it. I didn't get back to see them again, and consequently they didn't get recommended by me for an award.
(since 2004)
CT Teams - What does your school system provide your team WDAtiyeh General Forum 5 03-05-2007 06:23 PM
What does your robot ACTUALLY do? whytheheckme Rules/Strategy 9 02-13-2007 11:13 PM
What does your robot go for Dominicano0519 Programming 0 03-07-2006 05:26 PM
What does your robot do? Squeje250 General Forum 11 02-22-2005 09:18 AM
What does your robot really do? Scooter General Forum 5 02-26-2004 10:26 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
