Go to Post [You know you've overdosed on FIRST when...] When you discover that the cure to the swine flu is "oink oink BOOM!" - Katie_UPS [more]
Go Back   Chief Delphi > Technical > intelitek easyC/REC information > easyC PRO
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 02-28-2008, 10:26 PM
g_less1902 g_less1902 is offline
Rookie Year: 2007
g_less1902 is an unknown quantity at this point
Gyro Results
Hi,
Below is an EasyC sample program to test our ADXR300 from Sparkfun.
When I manually rotate the gyro 90 degrees, the result I get is about 35 degrees.
We tested the 80Deg/s from this years kit, and the 150Deg/s from last years kit, and they work correctly in EasyC.
In ChiefDelphi there is a thread to multiply the answer by 2.5.
But it doesn't look like it is correct.
I tried using Kevin Watsons IFI code in MPLab, and the gyro works correctly,
and I get expected results, however all of our code has been built with EasyC.
I downloaded the Jan 2008 WPILib libraries, and installed it in EasyC, but still don't get the expected results.
Is there something I am done incorrectly?
Thanks,
Eric Grajales
#include "Main.h"
void main ( void )
int gyroval = 0;
long cnt = 0;
SetGyroType ( 1 , ADXRS300 ) ;
InitGyro ( 1 ) ;
Wait ( 2000 ) ;
SetGyroDeadband ( 1 , 5 ) ;
StartGyro ( 1 ) ;
while ( TRUE )
gyroval = GetGyroAngle ( 1 );
if ( (cnt % 5) == 0 )
PrintToScreen ( "GyroVal = %d\n" , gyroval ) ;
cnt = cnt + 1;
// Arcade2 ( 1 , 2 , 1 , 1 , 3 , 1 , 0 , 0 ) ;
Wait ( 100 ) ;
Unread 02-28-2008, 11:25 PM
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Gyro Results
We had a similar experience with our ACXRS300 and EasyC, but not as severe as yours. For our purposes it's no big deal. I would try decreasing the deadband and see if that helps.
Also take the wait(100) from the bottom of your code. Also the wait (2000) after InitGyro is unecessary as the InitGyro has a built in pause to center the gyro.
Unread 03-02-2008, 04:08 PM
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Re: Gyro Results
Call SetGyroType ( 1 , ADXRS300 ) ;
after InitGyro ( 1 ) ;
Intelitek Support
[BFIRST Team 146 Blue Lightning - Alumni[/b]
FIRST Team 40 Checkmate
gyro captainking General Forum 4 02-03-2008 09:25 PM
arm-limitting gyro PD loop producing some strange results ZZII 527 Programming 8 02-16-2005 01:30 AM
Gyro magical hands Programming 2 01-14-2005 07:57 PM
gyro odin892 Programming 0 04-08-2003 08:59 AM
Gyro archiver 2001 2 06-23-2002 10:11 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
