Go to Post A shaft that yielded is just as useless as a shaft that broke. - Chris is me [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Team 221 LLC
ADVERTISEMENT
Unread 04-25-2008, 09:46 AM
T3_1565 T3_1565 is offline
User Error.... Recalculating.....
AKA: Linkage Designer :D
FRC #1565 (T3 Think Tank Technologies T3)
T3_1565 has much to be proud ofT3_1565 has much to be proud ofT3_1565 has much to be proud ofT3_1565 has much to be proud ofT3_1565 has much to be proud ofT3_1565 has much to be proud ofT3_1565 has much to be proud ofT3_1565 has much to be proud ofT3_1565 has much to be proud ofT3_1565 has much to be proud of
Send a message via MSN to T3_1565
pic: 1565 Linkage Troubles
Unread 04-25-2008, 09:48 AM
billbo911's Avatar
billbo911 billbo911 is offline
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: pic: 1565 Linkage Troubles
Oooo, Oooo. Mr. Cotta, Mr. Cotta.
(Sorry, I'm probably to old for most of you to get the reference.)
Is it the "S" shaped link bar??
So long and thanks for all the fish!
CalGames 2009 Semi Finalist, CalGames 2009 Autonomous Champion Award winner
Sacramento/Davis 2010 Creativity in Design winner, Sacramento/Davis 2010 Quarter finalist
2010 Madtown Creative Design Award, 2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award,
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
Unread 04-25-2008, 09:49 AM
JesseK's Avatar
JesseK JesseK is offline
Flybotix Fanatic
FRC #1885 (iLITE)
Linkage arm is bent.
Linkage bolt is not perpendicular to the linkage arm.
Also, is it just me or does it look like the entire linkage piston is unseated?
Healthy people — who know how to deal with disappointment, who have given up on the idea of magic bullets, who don’t watch TV indiscriminately [are] fulfilled by things that don’t cost money
I’m talking about the real fundamentals of being an empowered, self-directed human being. Creativity. Curiosity. Resilience to distraction. Patience with others. And to make these all possible: self-reliance — an unswerving willingness to take responsibility for your life...
How to Make Trillions of Dollars
Want to be a better cook? Do 5 recipes from Plenty on 5 weeknights after work. Eat the leftovers for lunch.
Unread 04-25-2008, 11:27 AM
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
PHL to STL in 2013
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Reminds me of when this happened at GLR to our robot.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alumnus: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Taking a break from robots. My Homebrewing Blog
Unread 04-25-2008, 11:33 AM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: The mentor formerly known as squirrel
FRC #1726 (N.E.R.D.S.)
Flat bars aren't very strong in compression...maybe try angle next time?
Unread 04-25-2008, 11:49 AM
So many people have said that to me at one point or another!!
Next time we will make sure that the outside frame doesn't get shifted (more bracing fixed the problem completely) lol. The flat stuff is strong enough, and only in that rare occasion would angled be nessacary. Unfortnatly angled pieces take up a lot of space. we may dimple them for next year though (raise the middle, so it is very slightly concave or convex)
JeeseK good work on the bolt!! The bolt is out of alignment because the two bars connected to it are also bent (just not nearly as badly as the long link )
Team 1565
Think Tank Tech
Unread 04-25-2008, 11:53 AM
MrForbes's Avatar
You could probably get away with cutting the flange off the angle for several inches at each end. The dimpled center idea is good too, if you can figure out an easy way to do it. This is pretty common in linkages on real life machines (for example the flat bar that connects the inner door handle in a 1950s chevy).
Unread 04-25-2008, 11:57 AM
lol.. seems like we found that dimple idea from somewhere eh??
Team 1565
Think Tank Tech
Unread 04-25-2008, 01:28 PM
A_Reed's Avatar
A_Reed A_Reed is offline
College Mentor/FIRST Volunteer
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
In our shop we have what looks like an ancient machine that will put a big long dimple down the middle of sheet metal and such, a bead roller. we used it on paper thin and flimsy lexan in '06 and it seemed to work really well at giving some added strength.
Unread 04-25-2008, 01:38 PM
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (Tech Tigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Ya that looks pretty nasty. I wish I had a picture of the 3/8ths aluminum bolt we broke in half at champs and the welds that broke off our elevator bearing holder tabs the very first qualification match of the day on Friday. Quite funny stuff looking back at it now, not so much at the moment though. I hope you guys got everything up and running and were able to over come that little bump it looks like you took.
-Good luck
Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
Student at Florida Atlantic University
Urban planning major aka I design cities
Unread 04-25-2008, 01:57 PM
we managed to fix the linkage in about 10 mins lol flat bar is plentiful so we just made a new one!!
Team 1565
Think Tank Tech
Unread 04-27-2008, 11:13 AM
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
Rookie Year: 1999
robostangs548 has a reputation beyond reputerobostangs548 has a reputation beyond reputerobostangs548 has a reputation beyond reputerobostangs548 has a reputation beyond reputerobostangs548 has a reputation beyond reputerobostangs548 has a reputation beyond reputerobostangs548 has a reputation beyond reputerobostangs548 has a reputation beyond reputerobostangs548 has a reputation beyond reputerobostangs548 has a reputation beyond reputerobostangs548 has a reputation beyond repute
Send a message via AIM to robostangs548
Bummer, that is a real problem....
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 04-27-2008, 11:32 AM
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics) #2809 (K-Botics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Send a message via MSN to Jonathan Norris
I would defiantly recommend getting some sort of bend in that flat bar, or replacing it with angle if you do this drive in the future. With the angle you could mill down one of the sides down to like 1/4" so it wouldn't take up as much space, but shouldn't bend like flat bar will.
2013 FIRST World Champions (1241, 1477, 610)
Co-Founder of Syrp, Inc.
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 04-27-2008, 12:02 PM
Mill lmao... Does a hacksaw work??
We actually may have milling capabilities next year (fingers crossed) so it will turn out better. We will also be sticking with this for the next couple of years (game dependant of course) to prefect it and call it our own. This years was more of a large scale functional prototype, next year has about a billion upgrades to it
Thanks for the comments!
Team 1565
Think Tank Tech
pic: 1565 Twitch the missing Linkage Ball hold T3_1565 Extra Discussion 13 03-30-2008 01:00 PM
pic: 1565 Twitch the missing Linkage Underbelly T3_1565 Robot Showcase 12 03-17-2008 12:58 PM
pic: 1565 Linkage Drive System T3_1565 Extra Discussion 10 02-13-2008 02:44 PM
pic: 1565 Extended Version T3_1565 Extra Discussion 5 02-04-2007 09:20 PM
pic: 1565 Compact Version T3_1565 Extra Discussion 2 02-04-2007 07:37 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
