Go to Post Wisdom shared is priceless, isn't it? And timeless. - JaneYoung [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Delphi
ADVERTISEMENT
Unread 09-03-2008, 05:03 PM
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Send a message via Skype™ to sdcantrell56
pic: FR 1771 Drivetrain Revised
AKA: Stogi
Send a message via AIM to Akash Rastogi
Re: pic: FR 1771 Drivetrain Revised
Nice weight drop and design. Thinking about doing the same to parts of the sides?
My posts do not necessarily reflect the views & opinions of affiliated teams.
['12-'13]: Mentor FRC 2495
['11-'13]: Co-Founder/Mentor FRC 3929
['06-'10]: Student FRC 11- MORT
Unread 09-03-2008, 05:24 PM
AKA: Sean
Im thinkin about it but i dont know for sure. It would really be something that depends on the manipulator and 28lbs is lighter than probably 90% of drivetrains in FIRST.
2012 Peachtree Regional Champs
2011 North Carolina Regional Champs
2011 Peachtree Regional Champs
Unread 09-03-2008, 05:34 PM
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31 Send a message via Skype™ to chris31
Looks nice but also looks like alot of machining. Have you looked at how much you are gonna spend in machining costs/materials or is it all being student done or donated.
Unread 09-03-2008, 07:47 PM
R.C.'s Avatar
R.C. R.C. is offline
Ramping Up for the 2013 Season!
AKA: Owner, WestCoast Products & Design LLC
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Send a message via AIM to R.C.
Nice job, 28 pounds is fantastic!!!
Unread 09-03-2008, 08:01 PM
bmarick bmarick is offline
FRC #2374 (Crusader Bots)
Rookie Year: 2007
bmarick is on a distinguished road
intresting design
I have to agree with the wiegt statement about it being lighter than most out there so that will be a great advantage.
But why did u go with belts?
Unread 09-03-2008, 08:05 PM
Lead Mentor
AKA: OUTWORK US
FRC #0973 (GRR)
Are you sure you are accounting for the weight of all fasteners, bearings, washers, belts, etc. correctly?
2011 World Champions
Follow 973 on twitter, @FRC973
Like our Robots? Check out the CAD files of ALL our robots!
Unread 09-03-2008, 08:26 PM
AKA: Sean
I am going with belts because they are the absolute lightest option, they are easy to deal with in this particular drivetrain, and the are simply cool. Also the tensioning method on this drivetrain is very good and will allow us to set the proper tension and keep it this way.
This drivetrain is kind of an extreme study in light weight as it is single speed and belt driven. I am finishing up a new 2 speed transmission using #25 chain and will post that one up when done. Altogether the 2 speed version will probably gain ~4lbs however that seems like a very good tradeoff for the added performance.
This does require a decent amount of machining however a lot of the machining can be done in large batches (wheels and bearing blocks) and the rest is not that much really. We are fortunate to have a couple machine shops that donate time to us so we can have things machined.
The weight calculation are completely correct minus the actual belt and I believe 12 bolts so yes it is very close and there is still more weight that can be removed. One of the huge weight savers is the UHMW wheels which should actually be more dent resistant than aluminum.
Finally this drivetrain is not necessarily what the team will decide on. It does require a substantial amount of machining; however, it is the most cut down and easiest drivetrain to maintain. Tensioning is accomplished by turning a bolt and wheels/tread can be changed in a matter of seconds. Particularly if bumpers are allowed again I will push people in this direction if we can accomplish the machining.
I must say I have admired 254/968 for a long time for their drivetrains being the absolute minimum necessary and functioning imo as good or better than all other forms. Thanks for the Inspiration teams 60/254/968
pic: FRC 1771 Drivetrain sdcantrell56 Extra Discussion 24 09-02-2008 04:05 PM
pic: 1771 drivetrain machining sdcantrell56 Extra Discussion 3 02-15-2008 04:26 PM
pic: 1771 drivetrain complete 2 sdcantrell56 Extra Discussion 4 01-11-2008 11:57 PM
pic: 2008 drivetrain 1771 sdcantrell56 Extra Discussion 9 01-10-2008 10:55 AM
pic: Revised Ball Shooter cleonavicius Robot Showcase 7 01-29-2006 04:26 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
