Go to Post changing some 0 to 1s was a lot lighter and cheaper than most of the clutches I found. - IKE [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 01-04-2009, 06:08 PM
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
DS Problems
We are having an issue getting a battery voltage reading on the DS. We have updated firmware on the DS and still have the same problem...
When we "tether" the DS to the CRIO directly we just get 00.00V, the same happens on wireless communication.
Has anyone had a similar issue?
If so how did you fix it?
Thanks!
Unread 01-04-2009, 06:55 PM
DonRotolo's Avatar
Is wishing HE had summers off...
FRC #1676 (Pascack PI Oneers)
Re: DS Problems
We had the same problem - until we put the battery voltage jumper onto the correct two pins on the Analog Breakout in slot 1...
Try That.
Don
Unread 01-04-2009, 09:39 PM
popo308's Avatar
AKA: Brent
Re: DS Problems
Ok I will give that a shot tomorrow! Thanks!
Unread 01-05-2009, 09:16 PM
popo308's Avatar
AKA: Brent
Re: DS Problems
We put the jumper on the battery voltage pins on the first module and it worked for about half hour then cut out again.....
Anyone have any ideas why to DS is doing this?
Labview problems and code problems ajsetter Programming 25 01-18-2006 04:07 PM
Problems muy dificil Programming 5 10-26-2005 04:10 PM
PC problems. . . opnickc IT / Communications 5 01-12-2005 03:53 PM
Problems- archiver 1999 0 06-23-2002 10:00 PM
Problems, problems . . . archiver 2000 6 06-23-2002 10:00 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
