Go to Post FIRST prides itself on safety. It shouldn't be limited to only the pit area. - sanddrag [more]
Go Back   Chief Delphi > Technical > CAD
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Delphi
ADVERTISEMENT
Unread 01-05-2009, 12:06 PM
114Klaatu0x72's Avatar
114Klaatu0x72 114Klaatu0x72 is offline
DQN
AKA: Sean
FRC #0114 (EagleStrike)
Rookie Year: 2007
114Klaatu0x72 has a spectacular aura about114Klaatu0x72 has a spectacular aura about114Klaatu0x72 has a spectacular aura about
Send a message via AIM to 114Klaatu0x72
You cannot install this product on the current operating system
Hello. I am at my wits end. I can download the autodesk pro 2009 installer with the given download tool from the firstbase website. When I attempt to install autodesk pro 2009 after the download finishes, I can reach the autodesk install screen, but when I try to install, an error message pops up and states that I cannot install autodesk pro 2009 on my current operating system. This is wrong. It states that, on the firstbase website, that windows xp x64 professional sp2 is a supported OS, and that is what I am running, as of now. That is, at around 2100 yesterday, I installed sp2. My hardware is more than adequate, so I am certain that it has little to do with the issue (q6600, xvga 780i, xfx gtx260, 4GB ram, if anyone thinks that is the issue) I have other OS's , but I do not see how those would affect anything regarding the install. I have attempted multiple installs, but nothing changes. Autodesk is the only program that has done this, and I have not found anything relating to it in 100+ sites, threads, forums, i have searched. Any advise would be greatly appreciated.
Unread 01-05-2009, 03:49 PM
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
Re: You cannot install this product on the current operating system
There is another thread with a similar problem, http://www.chiefdelphi.com/forums/sh...ad.php?t=71241
I am not certain that the download tool works for 64bit , you need to click the link to manually download through your web browser. The file should be called StudentAIP_ACADM_32_64.zip and its (8.7MB )
624 - Cryptonite 2001-2003 --> 118 - Robonauts 2005 --> 2158 - AusTIN CANS 2007 --> 2587 DiscoBots 2008-2013
Andrew Lynch - R&D at Sparx Engineering
Unread 01-05-2009, 04:15 PM
DQN
AKA: Sean
Rookie Year: 2007
Thanks for the advise. I started downloading it earlier today, but the file size is huge (8.7 GB), which is why I didn't just hop on this file in the first place.
Unread 01-05-2009, 09:52 PM
DQN
AKA: Sean
Rookie Year: 2007
Well, I solved my problem. Update like mad. Even if you just installed all of the automatic updates and rebooted, do it again, and again, and again, or 6 times like me. Point and case, update your computer more often than every 3 or 4 years. It will save you a lot of time, id est 17 hours of searching + 8 hours of downloads.
tl;dr
keep your computer up to date.
You Cannot Graciously Accept Steve_Alaniz General Forum 238 11-11-2012 09:26 PM
Which operating system do you use/want to use? neutrino15 Programming 17 01-11-2008 11:05 PM
Thoughts on Linspire Operating System??? Elgin Clock IT / Communications 8 08-13-2006 01:41 PM
Current Monitoring system questions PyroPhin Technical Discussion 44 02-17-2003 02:34 PM
StangSense: WildStang's Current Sensing System Dave Flowerday Technical Discussion 12 04-05-2002 06:40 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
