Go to Post Woodie Flowers would like to win the Chuck Norris award. - Andy Baker [more]
Go Back   Chief Delphi > Technical > Programming > WindRiver C++
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
ITT Tech
ADVERTISEMENT
Unread 01-06-2009, 02:43 PM
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Axis Camera responding in the Vision Assistant but not in WindRiver
Hey all-
The camera is responding perfectly when connected to the computer by crossover in the Vision Assistant, but when it's plugged into port 2 on the CRIO with the crossover and running the SimpleTracker code with HSL thresholds widened enough to catch an image, the code fails to find any particle.
I've already run the Axis Camera Setup Utility, and both FRC/FRC and root/admin users exist. The camera is setup with IP 192.168.0.90. I don't know what I'm missing, but I'm sure that I'm missing something as teams HAVE been able to track particles with the WindRiver SimpleTracker example.
Any help would be greatly appreciated-
Dandon
Unread 01-07-2009, 10:20 AM
kyungjin kyungjin is offline
Software Specialist
AKA: Daniel
VRC #0646
kyungjin is an unknown quantity at this point
Send a message via AIM to kyungjin Send a message via MSN to kyungjin Send a message via Skype™ to kyungjin
Re: Axis Camera responding in the Vision Assistant but not in WindRiver
I think this is a problem many of us, including myself, are having. I haven't tried running any code when the camera is connected to the PC (I'll try it when I go to school in a few hours) but it all feels useless to me if it's not going to work when connected to the cRIO.
It's bad enough that there is poor documentation for the implementation of cameras in WindRiver... Hopefully FIRST or someone else will figure out this irritation and post step-by-step instructions sometime soon...
Unread 01-11-2009, 10:19 AM
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
Rookie Year: 2007
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
When we connect the camera directly to the computer with a crossover cable (and set the computer's IP to 192.168.0.6), we can open up the NI Vision Assistant, set the Axis' IP as 192.168.0.90, and acquire photos.
When we connect the camera to port 2 on the cRIO (and change the computer's IP back to 10.xx.yy.6 and connect all the cables properly), we can "see" the camera image by running LabVIEW, but we can't connect using the NI Vision Assistant no matter what IP we try for the Axis.
I guess this just means that, to use the Vision Assistant, you have to connect the camera directly?
Unread 01-11-2009, 11:50 AM
Mark McLeod's Avatar
Itinerant Programmer
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Yes, the Vision assistant will only work directly with the camera while it's connected to your PC.
"Always exaggerate. It makes life seem more interesting." - Robert Weber
Problems with the Axis Camera popo308 FRC Control System 16 01-15-2009 06:38 PM
Focusing the AXIS camera in LV Tanis Programming 3 01-03-2009 10:21 PM
Camera will track one light, but not two? Kevin Watson Programming 2 02-01-2007 09:34 PM
Camera did not work for well at the regionals, but worked great at home. Alan Ing Programming 12 04-17-2006 04:43 PM
Camera Not Responding To Code itzrobz Programming 2 02-05-2006 11:47 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
