Dashboard and Robot main with Axis camera
We have had our robot chassis rolling but when we began to play around with the Axis camera we tried to follow the setup for the camera but when deployed to the crio we recieve the camera image but now we cannot move our robot. All we get is flasing yellow onb the jaguars. Is this an issue with the Robot main code that is from the LAbview Main. I am sure we are missing something but with out an actual programing class or professional as of yet we are trying to explore and troubleshoot issues. Seems like Chief Delphi has alot of answers so if anyone can help thanks a ton.
Re: Dashboard and Robot main with Axis camera
is your robot main deployed?
Flashing yellow means its lost its link. Not receiving a signal from you.
deploy robot main, click enable vision, let it run then go to view- getting started window-and pull up a dashboard project and run.
Double-check to make sure the DS screen doesn't show the robot in "disabled" mode. |
When we deploy the robot main we get to 36% then it seems to stop we clicked on close and then try to the enable vision and we can see pics from the camera but no movement. Just to get this right I open both of the VI's dashboard and Robot main, then go to run in each this should give us the default arcade control is that correct. I can see how the labview is going to give us alot of options but without getting the default program to load we are lost thanks for help thus far.
team 2883 |
no our donggle is working it shows up on the DS as enabled and disabled.
could we have an issue that we have the vision screen on robot main? We did not have the dashboard up is that an issue, do we have to have both of them or will it work with just running the robot main.
On the front panel of robot main, is the enable vision switch
| Problems with the Axis Camera | popo308 | FRC Control System | 16 | 01-15-2009 06:38 PM |
| AXIS Camera | nickmagus | Programming | 1 | 01-03-2009 07:06 PM |
| Program Axis Camera in c++ | excel2474 | Programming | 5 | 12-22-2008 04:14 PM |
| Dashboard with analog and dig inputs | Andrew Schreiber | National Instruments LabVIEW and Data Acquisition | 1 | 02-13-2006 09:48 PM |
| Emergency Help Needed on Main Board and Camera | amateurrobotguy | General Forum | 9 | 02-09-2006 08:22 PM |
