Go to Post Why subject your robot to a potential sensor failure when you can train a monkey (or a student, if monkeys are lacking) to put the tube at the right height every time? - JVN [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
ADVERTISEMENT
Unread 01-12-2009, 07:03 PM
Kahn! Kahn! is offline
FRC #1379
Kahn! is an unknown quantity at this point
Sorting 2-D Arrays [Labview]
I spent about 3 hours today circumventing the idea of sorting 2-D arrays in Labview. I had a 2-D array of 3 values. My plan was to reorder the array by one of the values while keeping the other values in the same index.
For example, this array:
[0] 6 14 28
[1] 7 81 4
[2] 1 15 38
I would want to sort it by column 3 making it this:
[0] 7 81 4
[1] 6 14 28
[2] 1 15 38
Does anyone know of a simple way to do this, or should I stick with my excessive, hard-to-follow code that I don't think I'll ever understand now that I've finished writing it?
Unread 01-12-2009, 07:10 PM
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
Rookie Year: 2007
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: Sorting 2-D Arrays [Labview]
With only three elements, it may be enough to avoid "sorting" sorting altogether, and just use a few IF statements. Not practical for larger sorts, but it might be best in this case.
Unread 01-12-2009, 08:21 PM
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
have you considered storing the 2d array as a 1-d array of clusters? that way you could store the item you want to sort by in the first slot and just do a 1-d built in sort.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 01-12-2009, 08:28 PM
FRC #1379
As a matter of fact, I just got the same response from one of our mentors (aka my brother) and it's working perfectly.
Thanks.
Unread 01-12-2009, 08:58 PM
no team (Team NI)
Unfortunately, there is no easy way to tell LV exactly how to sort more complicated data containers. LV deals with almost any type, but only 1D containers, sorted by first, then second, etc, and only in ascending order.
The attached snippet shows how to build an index array, then rebuild the 2D array based upon the indices.
Greg McKaskle
2008 Match Sorting Algorithm GeeForce Rules/Strategy 1 01-09-2008 08:41 PM
Sorting out Digital NASA TV Billfred General Forum 2 12-03-2007 05:55 PM
pic: Sorting drill bits Andy Baker Extra Discussion 12 02-16-2005 08:46 PM
Arrays on the PIC? scitobor 617 Programming 8 12-06-2004 08:10 AM
EduCAD and Arrays!!!!! Sachiel7 Programming 14 11-03-2003 02:21 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
