Go to Post The FIRST community will always step up in times of need. - nikeairmancurry [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 01-13-2009, 02:51 PM
bobbyt14 bobbyt14 is offline
FRC #0744
bobbyt14 is an unknown quantity at this point
dprintf
so the vision docs say that dprintf is supposed to print to a file in the root directory of the robot when SetDebugFlag() is set correctly. When I run programs initialized in this way, no file exists when I ftp the root file directory.
I'm wondering if there's some additional function i need to flush the file or some other way of running the robot (rather than download the code and reset the robot in windriver).
thanks
Unread 01-15-2009, 12:24 PM
foemill's Avatar
foemill foemill is offline
What do you mean it's overweight?
AKA: Eric Miller
FRC #1270 (Red Dragons)
Rookie Year: 2007
foemill is on a distinguished road
Re: dprintf
Here's a blurb from the FRC_Visio_API docs:
SetDebugFlag
Sets the debug flag to write to a file or console output. The debug files are written to the root directory
and are called “filename.debug” where filename = name of the calling routine.
The files may be ftp’d to
the PC for inspection. Be careful to remove these periodically so that they do not get too large and fill up
the disk. It is recommended to use file debug levels only during active debugging, and turn off debug (or
screen only) most of the time.
void SetDebugFlag ( FrcvDebugOutputType flag )
Parameters:
flag – Debug output type. This can be:
DEBUG_OFF, // no debug
DEBUG_MOSTLY_OFF, // only critical/fatal errors logged
DEBUG_SCREEN_ONLY, // no file, only console
DEBUG_FILE_ONLY, or // no console, only file
DEBUG_SCREEN_AND_FILE. // both console & file
Are you setting "funcName" to some string value in your function?
EX:
char funcName[] = “someFunctionName”;
dprintf(LOG_DEBUG, "Test from %s", funcName );
thanks
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
