Go to Post Why do FIRSTers think we're better? ...because we hold values like honesty, integrity, and intelligence dear... - Redneck [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 01-19-2009, 01:29 PM
CDH Jeff's Avatar
CDH Jeff CDH Jeff is offline
FRC #2450 (Raiderbots)
Team Role: Electrical
CDH Jeff is an unknown quantity at this point
Ground Clearance
Is there a specific height off the ground that parts of the robot have to be, other than the wheels? Or can something like, say, a ramp touch the floor?
"why are 'standard' and 'metric' different?! metric should be the standard!"
Unread 01-19-2009, 01:55 PM
EricH's Avatar
EricH EricH is offline
...has read the 2012 Manual
FRC #0330 (Beach'Bots)
Send a message via Skype™ to EricH
Re: Ground Clearance
The rulings on Q&A seem to indicate that the only reason something can touch the floor is for feedback, and even then, it's limited. If you put a ramp on the floor, you'll be called on <R06>.
As for specific heights, the bumpers have to be in the bumper zone (Section 8.2) and the trailer hitch has to be at a certain height.
Paths a rules question takes:
Official: Post to Q&A-->GDC reviews-->Official answer posted on Q&A.
Unofficial: Post to CD-->CD views and comments, sometimes using The Manual and interpreting it-->Somebody goes the Official route -->Answer gets posted on CD eventually, as a quote from Q&A.
Which one takes longer for an official ruling? Therefore, which one makes more sense to use?
Unread 01-19-2009, 02:03 PM
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
My week-old QA interpretation was that anything you want can touch the floor, so long as it does not provide sufficient drag or thrust to affect the low-friction dynamic. If you coated the floor-contacting portion of your ramp with rover-wheel material, then it would certainly not provide any traction or braking beyond what you could expect with the wheels.
edit: I can't find the QA response that I had justified that in my mind with, ignore me until I find it.
edit2: Here's the QA response, which gives a pretty broad ruling:
1. Other parts of the Robot may contact the floor, as long as the part does not provide any traction for the Robot.
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #1729 (Plan B)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
There is no specific height that the robot must be (other than Erics points). Anything touching the floor that could be considered a traction device (even if it produces very little to no traction) will be cause for the inspectors to look closer and possibly fail your robot at inspection.
Between the regolith sheets (at the Kickoff in Manchester) there were small ridges. I'd suggest at least an 1/8" clearence for any non wheel part.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 01-19-2009, 02:14 PM
EricH's Avatar
You might read the most recent batch.
For example, there's this one, which pretty much bans slick balancing items, even if they won't affect the CoF.
There's also this one, which effectively rules that you MUST use the Rover Wheels for traction--having the same material on something else is illegal if it's used for traction.
They've tightened up a little bit. It's not going to affect many designs, I don't think, but it's enough to affect your interpretation a bit.
Unread 01-21-2009, 01:58 PM
Unsung FIRST Hero
Broadcast Eng/Lead Robot Inspector
AKA: Big Al
FRC #0111 (WildStang)
Rookie Year: 1996
Jeff,
There are a few rules that come into play here, but the test will be if the device contacting the floor provides traction or braking (more than 5% in any direction) in addition to the wheels provided and that said device does not damage the playing field surface. That second one is far easier to determine. I am guessing you think that that a ball chute that follows the floor is needed to pick up balls. If you were to investigate a little further, I think you would find that the ball diameter is sufficient to allow pickup without touching the floor.
Al
WB9UVJ
www.wildstang.org
________________________
Season Eighteen, what a spectacular year! It's has been a bumpy ride. All is better now, new parts are working fine. Champs were spectacular!
pic: Virginia's rear ground clearance falconmaster Extra Discussion 7 01-25-2008 10:31 PM
Think about Robot Ground Clearance ggoldman General Forum 12 01-10-2007 07:22 AM
Chassis Clearance T3_1565 Technical Discussion 7 01-08-2007 05:02 PM
how important is ground clearance? Zippiot Technical Discussion 10 02-16-2005 10:56 AM
pic: Ground Clearance (or the lack thereof) ahmed Robot Showcase 14 02-15-2005 04:02 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
