Go to Post I personally think a large trophy and that warm, fuzzy feeling you get inside is a satisfactory prize for winning a competition. - InfernoX14 [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
The Chrysler Foundation
ADVERTISEMENT
Unread 01-24-2009, 08:47 AM
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
Team Role: Leadership
Rookie Year: 2007
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Digital Sidecar Not Working
hey everyone, 3 days ago we had all of our bench testing done and were fiddling with the camera, etc. everything on the electrical system was working fine. yesterday night, we re-wired the system to put on our robot, and the digital sidecar is not working. first, the 5v led would turn off when we pressed the enable switch. after relaoding fresh default software that porblem seems to have gone away. the only problem now is that we have no 6v power (and led) and the BAT led wont turn on. i have no idea what to do...
PS
vacuumed everything, tried swapping all of the parts, nothing seems to work....
Unread 01-24-2009, 09:00 AM
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: Digital Sidecar Not Working
The LED pattern (5V on, 6V and battery off) indicates that you are not getting power from the battery to the DSC. Check your breaker and your wiring. Most common issue to cause this is grabbing the insulation instead of the copper in one of the wago connectors.
Unread 01-24-2009, 09:01 AM
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
I can almost guarantee that you didn't strip enough insulation off of the wire that's inserted in the PD's WAGO. You aren't getting power to the DSC. Remove the power cable from the PD, strip off a bit more insulation and re-WAGO.
A word of warning - if the 37-pin cable that connects the DSC to the cRIO is present and the DSC has no power (as is probably your case), the 5V LED on the DSC will be on but somewhat faint and the 6V and 12V LEDs will be off. In this example, the cRIO is generating TTL/CMOS level digital outputs that partially providing power on the DSC's 5V rail. All 3 power LEDs need to be fully on (5V, 6V and 12V).
Russ
Unread 01-24-2009, 09:09 AM
tseres's Avatar
Rookie Year: 2007
thanks guys. it was the connection and tbad stripping job.
Unread 01-30-2009, 06:52 AM
Jared341's Avatar
Jared341 Jared341 is offline
Congrats to the Champs!
AKA: Jared Russell
FRC #0341 (Miss Daisy)
Jared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond repute
Send a message via AIM to Jared341
I assume that the LED pattern:
5V = ON
6V = ON, but dimmer than 5V
12V = OFF
would also most likely be caused by a bad WAGO connection?
Unread 01-30-2009, 07:29 AM
Rookie Year: 2000
5V = ON
12V = OFF
It could also be a short circuit on the 6V supply, but I would start with the WAGO.
Unread 01-30-2009, 08:00 AM
Unsung FIRST Hero
Broadcast Eng/Lead Robot Inspector
AKA: Big Al
FRC #0111 (WildStang)
Rookie Year: 1996
Remember that the manufacturer's spec is to strip about 1/2" to insure that there sufficient wire to grab inside the contact area and still prevent the insulation from entering the contact area. If you cannot see a little copper when looking into the contact after wire insertion, you did not strip enough. If copper is extending beyond the walls of the terminal after insertion, you didn't insert the wire far enough or you stripped off too much insulation.
Al
WB9UVJ
www.wildstang.org
________________________
Season Eighteen, what a spectacular year! It's has been a bumpy ride. All is better now, new parts are working fine. Champs were spectacular!
Unread 01-31-2009, 01:27 PM
z3rg0v3rl0rd z3rg0v3rl0rd is offline
FRC #1014 (Bad Robots)
z3rg0v3rl0rd is an unknown quantity at this point
When we opened up our sidecar and examined the circuit board, the c6 capacitor was not soldered on both pads. Has anyone else found this problem?
Unread 01-31-2009, 01:50 PM
infiniteloop infiniteloop is offline
FRC #1014
infiniteloop is an unknown quantity at this point
I should add that 2 of our 3 sidecars have this defect.
Unread 01-31-2009, 04:22 PM
That's a known defect that shouldn't cause any issues since the board is conformally coated. I believe this was covered in an early update to teams.
Russ
Digital Sidecar Problems cabbagekid2 FRC Control System 13 01-31-2009 04:23 PM
Fusing for Digital Sidecar (was: HIZZELP) KilroyLaxer FRC Control System 4 12-15-2008 07:44 PM
p2 not working? Lone_Wolf92c Programming 5 02-22-2008 07:49 AM
IR Board Not Working (But NOT Fried) itsme Electrical 2 02-18-2008 05:11 AM
Camera not working st1nkm4n Programming 0 01-31-2006 06:23 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
