Is there some sort of electronic quick release mechanism that we can use on a motor being used as a winch? I think I remember there being a mechanical one a couple years ago, but we got rid of it last year.
Re: Quick release
3 years ago we used a small pneumatic piston to pull a "grenade pin" from a mechanism at the start of the match; it was there for safety and we didn't want it released until nobody was near-by.
Re: Quick release
Any electronic mechanism is going to be illegal as an electronic solenoid or extra motor or something. So you'll need to go with some kind of mechanical quick-release. There's a rather lot of options, but it depends on how much load you're releasing and how you're winding up the load in the first place.
Re: Quick release
We want to be able to set and release it multiple times throughout the match as we are using it for our ball scoring device.
Edit: We are using a fisher price motor to wind up the load. I'd estimate that it is about 15-25 lbs of force. Last edited by Hastypickle : 01-26-2009 at 08:42 PM. |
Re: Quick release
You do have the hitec servos and FTC servos available. Could be used as an actuator for a drum brake. Multiple servos could be ganged together if the force of one is not enough.
Re: Quick release
I actually happened upon a ridiculously effective quick release based around an FP, a low ratio BaneBot planetary transmission, and a worm-wormgear set. With a servo with a cam to shift things. I can sketch something up in Inventor if you want to see how it'd work.
Re: Quick release
I was thinking maybe the pneumatic actuator could be used, but I don't know how much force that would be able to hold. |
Re: Quick release
If you design it right, it can hold a lot. I know that 330 fired a short-throw cylinder into a winch powered by 2 FPs back in 2004 to keep us on the bar. We never had a problem with it.
Re: Quick release
1391 used a 1 inch pneumatic piston to hold back our launcher in overdrive. I think we had about 300lbs force held back by a simple lever actuated by the one inch piston.
Depending on the device you are trying to hold back, there are so many ways to do it with pre-made devices but I would recommend just throwing something together that does the job and that is simple and easy to make another one of at a competition. |
#10
Re: Quick release
the equation is f=pa, or force = pressure x area. for the example above, in the extend direction it is f = 60 pounds / inch^2 x 3.14 (.375^2) = 26.49 pounds for the retract, you have to subtract the area of the internal rod, so the effective area is reduced (0.25 diameter = .125 radius) f = 60 pounds / inch^2 x (3.14 (.375^2) - 3.14 (.125^2)) = 23.55 pounds. |
#11
Re: Quick release
Mod an Andymark Gen1 shifter, it has the release ability you're looking for as well as the ability to "wind up" whatever you're looking to build, if you do your design work right.
#12
Re: Quick release
you could just have a piston push all of the rope off of the open end of the reel.
#13
Re: Quick release
Fishing reel? Motor to wind, servo to release.
#14
Re: Quick release
http://www.chiefdelphi.com/media/photos/31538
http://www.chiefdelphi.com/media/photos/31539 you dont need pneumatics for quick releases.... ![]() |
#15
Re: Quick release
You could take a pipe, cut it in half and put it on a shaft, make a notch in one and and a reciprocating notch on the other, mount fasten the left side of the cut pipe to the shaft, use a pnuematic shaft to push the two pipes together while winding, then use the piston in the other direction to dislodge the pipe... If that makes sense.
Edit: 400th post. |
| pic: Bike quick release part 2 | falconmaster | Extra Discussion | 4 | 01-24-2008 06:39 AM |
| Quick Vacuum Release | Calvin_1631 | Pneumatics | 8 | 02-05-2007 07:49 PM |
| Quick release wire harness | mechanicalbrain | Electrical | 2 | 01-08-2006 02:36 PM |
| openFIRST Release -- 'Twas the Release Before Christmas | Timothy D. Ginn | openFIRST | 3 | 12-25-2003 10:44 PM |
| Quick release battery connector and 120 amps | n[ate]vw | Electrical | 6 | 01-18-2003 10:41 PM |
