Go to Post It is a little known fact that Team 1114 is actually "General Motors Canada and Hogwarts Academy" The whole Niagara FIRST thing is just a cover to keep the magic arts concealed from us muggles. - dtengineering [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ProCare Services
ADVERTISEMENT
Unread 01-28-2009, 05:18 PM
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Team Role: Mechanical
Rookie Year: 2007
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
GLOBE GEARBOX [edited]
Does any one know how to seperate the globe motor from the gearbox...
This has baffled the Game Mech Dept for awhile now, and its getting a little late, so some of the members just want to throw it at a wall and see what happens...
Anyone who can help
Thanks
"Measure once, cut twice... wait... what?"
"Two things needed to build a robot.. WD40 for the things that don't move but should, and Duct tape for the things that move but shouldn't"
Unread 01-28-2009, 05:34 PM
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
Fan of Canadaland
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
Send a message via AIM to Travis Hoffman Send a message via Skype™ to Travis Hoffman
Re: GLOBE GEARBOX [edited]
Anyone who can help
Thanks
I believe it involves getting a punch and tapping in the little roll pins around the gearbox/motor interface. Tapping them inward will allow you to remove the motor. After this, take out the roll pins, do your mods, reassemble the components, then tap the roll pins back in.
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Time Warner Cable Warren G. Harding FLL Regional Partner
Unread 01-28-2009, 05:36 PM
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Did this the other day.
Remove snap ring on shaft.
Tap roll pins INTO gearbox.
Use chisel/flathead screwdriver to GENTLY tap the gearbox apart from the motor.
The end.
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists (3rd seed), Innovation in Control Award
2011 Boston Regional Finalists (2nd seed), Industrial Design Award
2012 New York City Regional Winners
2012 Boston Regional Finalists (2nd seed)
2013 Orlando Regional Finalists (2nd seed), Industrial Design Award
2013 Boston Regional Winners (1st seed)
Unread 01-28-2009, 05:38 PM
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
There are three spiral spring pins inserted into holes around the circumference of the gearbox, near to the motor. Each is about Ø0.093 in, and 0.188 in long, if I remember correctly. Using a small punch (or even the back end of a small drill bit in a drill press), press each of the pins into the gearbox. It should then come off easily, and the shaft and planet carriers will come out.
You're probably not going to like the motor pinion that you find inside, though. I'm not sure exactly what it is, but it's got very small teeth.
Unread 01-29-2009, 12:35 AM
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
you don't actually need to remove the c-clip on the output shaft when removing the gearbox - just tap in the set pins on the sides and pull the gearbox off. The pins push in quite a ways - over 1/8" for sure.
we just put one back together that was taken apart earlier - not too difficult once you figure it out.
Unread 01-31-2009, 06:36 PM
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Rookie Year: 2000
Kevin Ray is a jewel in the roughKevin Ray is a jewel in the roughKevin Ray is a jewel in the roughKevin Ray is a jewel in the rough
What do you plan on doing? Are you going to remove the last stage? Doing so gets the speed up to 450 rpms.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2013 Dean's List Finalist- SBPLI Regional
2013 Excellence in Engineering SBPLI Regional
2013 Chesapeake Regional winner
2013 Quality Control Award, Chesapeake Regional
Globe Motors joesmomh00haha Technical Discussion 1 02-14-2008 09:36 AM
Globe Motors Guy_E Motors 10 01-21-2007 03:53 PM
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 06-05-2006 10:48 AM
Globe Motor archiver 2000 4 06-23-2002 11:15 PM
Globe Motor archiver 2000 0 06-23-2002 11:15 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
